• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    CAD Managers
    sgold
    Piping in an Inventor Standard license
    617 Views, 1 Replies
    09-28-2012 08:26 AM
    Design Suite Standard and thus Inventor Standard don't let you create/edit/modify piping.  BUT, will they let you open/measure an assembly that has piping in it?  We don't have many people who will edit piping, but they all need to be able to work with assemblies that have it included, so I'm trying to avoid the 25% markup of having to go to the next level.  Thoughts/Experiences?  Thank you!
    --Scott
    Scott G.
    Using Inventor 2013 and Vault Basic (New to Inventor)
    6 years Solidworks (v2006-2010)
    10 years Pro-Engineer (v13-WF2) w/ Intralink (2.0-3.0)
    2 years of Mechanical Desktop
    AutoCAD since R12
    First professional CAD: DrafixCAD
    Please use plain text.
    Valued Mentor
    CelticDesignServices
    Re: Piping in an Inventor Standard license
    11-12-2012 10:56 AM in reply to: sgold
    Scott,
    From what I've seen with "lower" versions of Inventor opening files with piping, wiring, etc created in higher versions of Inventor (Inventor LT versus Inventor Routed systems) has been you will or should see the piping models, but you won't be able to edit them. I can't recall what the error states, but you'll get one if you attempt to do such.
    Users should also have no problem measuring the piping in the assemblies.
    Hope this helps.
    Feel free to contact me if you need more info or need help.
    Jim
    Celtic Design Services, LLC
    Inventor/AutoCAD/Vault WorkGroups
    Always for hire - celticdesign01ATyahooDOTcom
    http://www.linkedin.com/pub/celticdesignservices-llc/51/610/398/
    Please use the Accept as Solution and Give Kudos functions as appropriate to further enhance the value of these forums.
    Go raibh maith agat (in other words...Thank you!)
