Autodesk Technology Managers Forum
Share your knowledge, ask questions, and engage with fellow CAD/BIM Managers.
Message 1 of 42
857 Views, 41 Replies
Performance tips
So far, I haven't been able to find anything from Autodesk in ways to
properly set up a computer for the best performance. I've found information
on the video drivers which really doesn't apply to me
because it seems to deal with mostly 3D, and I don't do 3D. I've found and
set the 3GB switch with a noticeable performance boost. So, are there any
other tricks/settings to keep in mind?
Here's my specs:
AutoCad 2010
HP workstation
Vista Home Premium SP1 64bit
Intel Core2 Quad CPU Q6700 @ 2.66GHz 2.67GHz
6GB of RAM
NVIDIA GeForce 9500 GS video card
Gateway 22" Widescreen HD Monitor
From what I gather, this should be a pretty fast system. Only, it drags
somewhat. I'm not able to keep up with all the technological stuff like I
use to. I found the 3GB switch trick by accident. I just wish there was a
website or something which would explain the different configurations and
settings which work best with the different variations of operating systems,
Autodesk products, processors, etc. I know that leads to a lot of
possibilities, but it would be something that would be greatly appreciated
for all of us who cannot keep up with the newest trends or ways to
circumvent defaults to improve performance.
TIA
Rabbit @ *ork
41 REPLIES 41
Message 2 of 42
Your AutoCAD and Windows versions are...?
PC specs?
Dean Saadallah
http://LTisACAD.blogspot.com
Message 3 of 42
They're in my original post.
Rabbit @ *ork
Stupid people shouldn't Cad.
"Dean Saadallah" wrote in message
news:6157810@discussion.autodesk.com...
PC specs?
Dean Saadallah
Message 4 of 42
LOL!
"Rabbit" wrote in message
news:6157833@discussion.autodesk.com...
Rabbit @ *ork
PC specs?
Dean Saadallah
Message 5 of 42
rgorman
Go to the "Enable/Disable Digital signature Icons" section of the Acad Icon choices. (right click on the Acad Icon)
UNCHECK the box. It helps when scrolling through the directories when opening a drawing or looking for a block or something.
Message 6 of 42
See, there's something that should be included in a
list somewhere.  Thanks Mr. G.
Rabbit @ *ork
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Go
choices. (right click on the Acad Icon) UNCHECK the box. It helps when
block or something.
Message 7 of 42
Correct me if I'm wrong, but you don't need the 3GB switch in a 64 bit OS, do you? It is supposed to address much more RAM automatically for native 64 bit applications.
Message 8 of 42
nintendo wii
wii fit
acad 2010
PJ
PC specs?
Dean Saadallah
Message 9 of 42
I dunno for sure.  But, I put in
size=3>"bcdedit /set IncreaseUserVa
3072"
I could notice a significant improvement in how
AutoCad ran afterwards.
Rabbit @ *ork
Correct
applications.
Message 10 of 42
That is correct
Dennis Jeffrey, Autodesk Inventor Certified
Expert
Autodesk Manufacturing Implementation Certified
Expert.
Instructor/Author/Sr. App Engr. Tel. (260) 399-6615
AIP 2008 SP3,
AIP 2009-SP1 PcCillin AV
HP zv5000  AMD64 2GB - Geforce Go 440, Driver:
.8185
XP Pro SP3, Windows XP Silver Theme
href="http://teknigroup.com">http://teknigroup.com
Message 11 of 42
Thankyouthankyouthankyou!
> Icon choices. (right click on the Acad Icon) UNCHECK the box. It helps
Message 12 of 42
Uh, heck yes that's a fast system. What, exactly seems to 'drag'? Does
your cursor stick after keying a command at the command line? If so, is
your command line un-docked? Does your cursor stick after selecting a
dimension object with the properties palette open? Mine does, but it
would be nice to know if a faster system would fix that.
Have you seen this site?
Your CPU:
http://www.cpubenchmark.net/cpu_lookup.php?cpu=Intel+Core2+Quad+Q6700+@+2.66GHz
Your video card:
http://www.videocardbenchmark.net/video_lookup.php?cpu=GeForce+9500+GS
Smokin' .-)
> somewhat.
Message 13 of 42
You are correct, Owen. The /3GB switch does not
exist for 64 bit operating systems. Native 32 bit applications will address the
full 3GB automatically on a 64 bit OS.
With that being said, nobody has mentioned
that the user is running AutoCAD 2010 which does have a native 64 bit
installation on a 64 bit operating system.  There shouldn't be any
performance issues whatsoever with this rig.
style="BORDER-LEFT: #000000 2px solid; PADDING-LEFT: 5px; PADDING-RIGHT: 0px; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px">
Correct
applications.
Message 14 of 42
You read the posts
Or just glance at them?
Usually you
Are quite adept at giving
Reams of advice,
Enough to satisfy
Any poster.
Nevertheless
I deem that in this
Discussion you have shown.
Inadvertantly,
Or intentionally,
That you are glossing.
TDP
PC specs?
Dean Saadallah
Message 15 of 42
Well heres one. Keep ur pc clean! Got to a stage the other day when one of our machine kept crashing as well as stalling. I couldnt figure out what the hell was going on. Opened it up and it looked like a family of dust had moved in with the relatives. After that, not one issue.
Intel Bade Axe XBX2
Intel Q6600 2.4
8 Gig Ram
8800GT 512 MB
XP Pro 64bit SP2
2 x 22" Acer AL2216W
Message 16 of 42
Explain the need for the 3G switch then... .
Dean Saadallah
Message 17 of 42
Princess Jamie wrote:
> You read the posts
> Usually you
> Reams of advice,
> Enough to satisfy
> Any poster.
> Nevertheless
> I deem that in this
> Inadvertantly,
> Or intentionally,
> TDP
> PC specs?
Message 18 of 42
So, in other words, AutoCad has gotten so full of
crap that it's almost impossible to get any performance without breaking the
bank on the hardware.
Rabbit @ *ork
the full 3GB automatically on a 64 bit OS.
Correct
bit
applications.
Message 19 of 42
Did you read that anywhere in my post, Jamie? I
said that you're running a 64 bit operating system, on which the /3GB switch
doesn't exist - which is not the fault of Autodesk...for that matter, it's not
anyone's fault, it's how the system just *works.* AutoCAD does have a
native 64 bit installation, which you should have noticed during install (check
to see if Autodesk folders exist in C:\Program Files or C:\Program Files (x86)
to verify.) Other than your video card (which is not listed as supported nor
even tested for any AutoCAD based product) you have fairly good hardware. So in
other words, you're getting more performance out of AutoCAD than most, and no
memory switch is going to assist you in stretching that even
further.
dir=ltr>
"Rabbit" <jamie_myers at yahoo dot com> wrote in message
href="news:6158582@discussion.autodesk.com">news:6158582@discussion.autodesk.com
Message 20 of 42
Easy there dude.  Dunno what I said to get
that kind of reaction.  Sheesh.
My point is this, if I'm getting more performance
than most, then I feel sorry for the most.  Because this is crazy.
Therefore, I've came here to see if there is something I was missing.
Something set wrong, or, loading incorrectly.  IF everything on this end is
fine, then AutoCad is bloated way too much and IT is the problem with the
performance.  If AutoCad is the problem, then I think I have a right, as a
customer, to express my concerns.
Sorry if I got your panties in a wad.
Rabbit @ *ork
(check to see if Autodesk folders exist in C:\Program Files or C:\Program
Files (x86) to verify.) Other than your video card (which is not listed as
supported nor even tested for any AutoCAD based product) you have fairly good
hardware. So in other words, you're getting more performance out of AutoCAD
than most, and no memory switch is going to assist you in stretching that even
further.
of crap that it's almost impossible to get any performance without breaking
the bank on the hardware.
Administrator Productivity
