CAD Managers
Member
Message 1 of 7 (858 Views)
Need repairing DWG. Can't open a saved DWG file in sketchbook Designer.
858 Views, 6 Replies
05-10-2013 09:09 PM
Hello I'm using student version of Autodesk Sketchbook Designer but it keeps crashing and today I cannot open a saved file. This file is very important to me so please help. I have tried open it with Autocad, DWG trueview and inventor but no luck. The file has been attached if anyone want to have a look at.
Kawin
Please help
*Expert Elite*
Charles_Shade
Message 2 of 7 (833 Views)
Re: Need repairing DWG. Can't open a saved DWG file in sketchbook Designer.
05-13-2013 06:11 AM in reply to: kawin13
Welcome to Autodesk Forums!
885 KB is pretty small for a DWG file.
Search your computer to see is there is an idk2.bak file.
Your file opened here but there is nothing in it.
No Blocks, Layer 0, only the expected Text and Dim Styles.
QSELECT returned that there are no objects in the current drawing.
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
*Expert Elite*
rkmcswain
Message 3 of 7 (811 Views)
05-15-2013 04:57 AM in reply to: kawin13
Is DWG the native file format for Sketchbook Designer?
You say "tried open it with Autocad, DWG trueview and inventor but no luck."
What does that mean, that the .DWG file will not open (crashes) or there is nothing in it?
Your attached drawing opens fine here, and DBLIST reveals there are no entites in it, and not much more. It looks like a standard empty template drawing.
Member
Message 4 of 7 (803 Views)
05-15-2013 02:26 PM in reply to: kawin13
The file is actually done in Sketchbook Designer and saved as Autocad DWG 2010 because it doesn't have native file name. Files that are done in sketchbook, even with the .DWG will not open in any other programs except Dketbook designer. My problem is that I cant open it in Sketchbook anymore.
Member
Message 5 of 7 (802 Views)
05-15-2013 02:32 PM in reply to: kawin13
**Edit**
The file will open in DWG viewer but it will appears as nothing in it. Try to open it with Sketchbook Designer, the program will crashes right away. Thank you.
*Expert Elite*
pendean
Message 6 of 7 (791 Views)
05-16-2013 06:20 AM in reply to: kawin13
One more time, from a third person: there is nothing inside the file you posted, regardless of what application is used.
Emtpy. Dead. Nothing in it.
Go find another DWG file that is substantially larger in size than this one.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Distinguished Contributor
Wanderer-MOTD
Message 7 of 7 (778 Views)
05-17-2013 11:40 AM in reply to: kawin13
Oh, so this is not natively a dwg file?
Can you try posting the original sketchbook designer file?
Melanie Perry
***not all those who wander are lost***
http://AUGI.com/Surveys
http://MistressOfTheDorkness.blogspot.com
My defunct profiles:
http://forums.autodesk.com/t5/user/viewprofilepage/user-id/651859
http://forums.autodesk.com/t5/user/viewprofilepage/user-id/644095
You are not logged in.
Manufacturing CAD & IT Manager Resource
Additional information for installing, licensing & deploying Inventor, the Product Design Suites and Factory Design Suites.
Need installation help?
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
