Timothy,
I haven't yet started to implement Named Plot Styles yet, due to a problem with
dealing with Architectural Desktop's subobjects inside AEC objects. This has
been fixed in R3, however, so I will probably start to incorporate them into our
way of doing things.
Named Plot Styles are just another abstraction of what's drawn to how it plots.
With color-based styles, which we've been using since day one, you assign a
color to a pen weight and adjust your drawing to match. Hence, you have a lot of
the old restrictive "All Colors Must Be Bylayer At All Times" rules in your
standards.
However, with Named Plot Styles you essentially throw that limitation out and
start over, assigning a Plotting Style to objects or layers - just as you would
a color or linetype. It's just another property of the object, but because it's
not tied at all to color, it gives you another dimension fo freedom in how you
are presenting your drawing.
It helps to understand Named Plot Styles if you think of the usual color-based
plot style table as what it really is - a table of 255 separate color plot
styles, one for each color. Once you divorce yourself from assigning colors to
mean plot weights, you'll find a lot of freedom in how to get reliable,
consistent output easily - much more easily than having things tied inexorably
to color.
For example, to turn an exterior elevation from normal monochrome black and
white to a full color plot using color-based plotting could be a nightmare. With
plot styles it's almost effortless, because color isn't a limiting factor.
I think both have their plusses and minuses, but the only real thing on
Color-based plotting's corner is the familiarity with it that everyone has. It
will take a while for named-based plotting to catch on, but I expect it will
take over as the default method of plotting.
It would also make the process of plotting someone else's drawings a simple
thing, instead of having to deal with .PC3 or PCP files and all that nonsense.
Matt
stachoni@bellatlantic.net
On Wed, 31 Jan 2001 09:10:15 -0800, "Timothy Rider"
wrote:
>I am looking for opinions on using Named Plot Styles vs. Color Dependent
>Plot Styles.
>This question has reared its ugly head during some recent CAD standards
>restructuring meetings in our office.
>From a CAD managers point of view, is one better or worse? Why?
>Any comments are greatly appreciated.
>Thanks
