Autodesk Technology Managers Forum
Share your knowledge, ask questions, and engage with fellow CAD/BIM Managers.
My first CAD test: Was I too tough?
255 REPLIES 255
Message 1 of 256
4019 Views, 255 Replies
all,
I've never given any prospective employee a "CAD Test," but I was asked to do so
today. I quickly came up with 20 questions which I figured any knowledgable
person who knows the program would be able to hit it out the park.
Instead, I got a serious case of deer-in-the-headlights-itis.
I didn't want to make it version specific, but I understand some questions would
not be answerable for someone running an older release, and gave the person a
pass in those cases.
I also didn't care if the questions were "useful" on a day to day basis; the
idea was to get an idea of how well the user knows AutoCAD.
So, I'll ask you guys: Was this a decent CAD questionnaire?
1. What are the names of the first 7 AutoCAD ACI colors?
1 =
2 =
3 =
4 =
5 =
6 =
7 =
2. What are System Variables? How are they used?
3. When dimensioning in Model space, what DIMSCALE value would you use for
dimensioning for a 3/16"=1'-0" plot?
4. When working with External References (Xrefs) what is the difference between
Overlay and Attach?
5. How would you specify a Viewport scale of 1/4"=1'-0" in a Paper Space
Viewport, using the Command Line?
6. What is a CUI file?
7. What is a fast method for selecting MText objects with a Style of "MEDIUM"?
8. What does the FROM osnap do?
9. What does Zoom Dynamic do?
10. What are the special rules concerning layers and colors in Blocks?
11. If you dimension two parallel walls and get a dimension of 14'-5 13/256",
what do you do?
12. What is one way of dimensioning something along an angle?
13. Explain the difference between the DIVIDE and MEASURE commands.
14. What does PSLTSCALE do?
15. What is an easy way to open an Xref from a parent file?
16. What is an easy way to close a Polyline?
17. What support file do you modify to create custom command aliases?
18. What is the command-line sequence you would use to change all Xref layer
colors to color #8 (gray)?
19. What does BATTMAN do?
20. What command do you use to change your default Plotter?
Extra Credit / Trick Questions:
1. During the MOVE command, what happens if you hit in response to the
"Specify second point or :" prompt?
2. What generally happens when you do a PERPendicular Osnap on a Spline curve?
I had some more trick questions, but since the first 20 didn't go so well, we
just called it a day at that point 😞
Matt
mstachoni@comcast.net
mstachoni@bhhtait.com
255 REPLIES 255
Message 141 of 256
yeah, back in my yuppie (hippie?) days i didn't give a darn about buying
things made overseas.......
blazers are always nice...
Steven Ondrias, Technician
President =====> Hunters of Texas
VP =====> Amigo and Jetta Society of America
Member =====> Ted Nugent Fan Club
C3DPOS dual 19's Matrox 650-128 XPpro sp2 dual P 3 Ghz 2GB ram
eagle point guru...
overall a nice guy......
t5's official sausage sender.....
"Dave Drahn" wrote in message
news:5571265@discussion.autodesk.com...
Nice. I like it (even though it's far'n). For mine just Google a white '99
blazer and put some Bridgestone A/T's on it.
"Steven Ondrias" wrote in message
news:5571097@discussion.autodesk.com...
hey, there... it made it.... here's another...
eagle point guru...
Message 142 of 256
On Tue, 1 May 2007 18:58:11 +0000, Warren Trost wrote:
>What happens if the block needs to be inserted on more than one layer where
>one layer is turned off but the other one is left on, such as section cuts
>on current and future construction where future may be off for some
>printings?
Our policy is that blocks are for simple things, which belong on a single layer.
When they do require multiple layers (= lineweights), such as a window w/muntins
in elevation, it's easy enough to create multiple block with the same IP, each
one inserted at the same IP using the INSERT osnap, and placed on the
approproate layer and perhaps Grouped together for ease o editing.
Matt
Message 143 of 256
On Tue, 1 May 2007 20:11:44 +0000, Dennis McNeal, AIA - Autodesk BSD
>13/256",
>what do you do?
>I'd be amazed at the accuracy of my drawing! 😉
The first thing I do in CAD training for any new employee is explain the
difference between Precision and Accuracy.
Ooo! New question for the test!
Matt
Message 144 of 256
hey, do you like off topic newsgroups with the smartest ACAD peeps ever?
"Kate M" wrote in message
news:5571243@discussion.autodesk.com...
We keep forgetting to mention that parallel cannot be used to pick the first
point of a line...only the second.
Does that help?
"Fred" wrote in message
news:5571147@discussion.autodesk.com...
Steven Ondrias wrote:
> oh, that's cuz you need to get away from the line, back to where a
> parallel
> line would be.... IOW, hover over the line, and go back to the point where
> you started the line.... cornfusing, i know, but makes sense after you see
> it work..... can't see too many uses for a civil environment though.......
> maybe laying out a parking lot.
I wish I could show you what my screen looks like. Not a single
parallel line.
Message 145 of 256
eagle point guru...
"Guess Who" wrote in message
news:5571292@discussion.autodesk.com...
Does that help?
> parallel
parallel line.
Message 146 of 256
she sounds like a cool chic. She'd love it over there. ----------------->
news:5571340@discussion.autodesk.com...
:-D
eagle point guru...
Does that help?
> parallel
parallel line.
Message 147 of 256
well, work it, dude!
eagle point guru...
Message 148 of 256
hey, here is the test I have used for years now. It has a lot of the same type of questions.
I don't care if people have this before the interview, because I ask them to elaborate on a few items.
man, I wish people would study this before an interview as it would double most interviewee's acad knowledge.
I would say Matt's test is very hard. Anyone not very experienced would miss a lot of questions.
I say that because it covers a large cross seciton of issues. It takes a while to cover all that and know it by heart.
I like hard tests though, they show managers that real work is hard.
Matt Stachoni
|>all,
|> 1 =
|> 2 =
|> 3 =
|> 4 =
|> 5 =
|> 6 =
|> 7 =
|>Overlay and Attach?
|>what do you do?
|>Matt
James Maeding
Civil Engineer and Programmer
jmaeding - at - hunsaker - dotcom
Message 149 of 256
snip>then the use of wildcards for layer control is extremely effective.
Agreed Matt, not a problem on my end.
Don Reichle
"The only thing worse than training your staff, and having them leave is -
not training your staff, and having them stay." 😮
A reminder taken from Graphics Solution Providers' Calendar page
!! Please discuss whatever we tell you with your SysMgr !!
!! They appreciate staying in the loop 🙂 !!
LDT-2K4
AMD Athlon64 2.2GHz 2GB RAM
XPPro 32bit SP2
WD Raptor 10K-rpm 37GB HD
Nvidia GeForce FX 5200 128MB
"The only Constant is Change".
"Matt Stachoni" wrote in message
news:5570243@discussion.autodesk.com...
On Tue, 1 May 2007 00:20:21 +0000, Don Reichle
wrote:
>Most often we wouldn't be changing all Layers colors in a particular XREF
>in
>this manner. Sometimes we want a certain Layer to be less "Screened" than
>the others in that XREF. Some need to stand out more than others.
Okay, but if your layering convention follows something logical, e.g. all
annotation is put on an ANNO layer, then the use of wildcards for layer
control
Matt
Message 150 of 256
Looks like I've got some reading up to do on BYBLOCK then.
Don Reichle
LDT-2K4
XPPro 32bit SP2
"Allen Jessup" wrote in message
news:5570265@discussion.autodesk.com...
I prefer byblock also.
"Lance W." wrote in message
news:5569736@discussion.autodesk.com...
heh, yeah I know but it offers a flexibility I like to have if needed.
jackshield wrote:
> BOOOOOOOOOO!
Message 151 of 256
I used to change xref layer's colors in this manner(-la c 8 *|*) but found that it caused
very bad side effects: Since the visibility of a layer is controlled by whether it's
color is positive or negative, it turns on all the xref layers. Today I use a custom
program to overcome that limitation but by using the layer manager, there are no such bad
side effects if you change the colors (because it retains the color signs).
"Don Reichle" wrote in message
news:5569979@discussion.autodesk.com...
snip>>> 18. What is the command-line sequence you would use to change all
>> Xref layer colors to color #8 (gray)?
>again, many new Users will not be frequenting the command line.
>Layer Filters, in Layer Manager is probably the most used method...
Yep, but I'm also interested in speed, which means to me a profound
understanding of the command line. I don't think you can know AutoCAD
without
understanding command line syntax.
'-la c 8 *|* "" ' is imminently faster than opening any dialog box -
particularly the layer dialog.
Now that I "see" it, it makes perfect sense.
But it was just hovering on the edge of my "dirt-dauber" mind until now. ;0)
I started reading this thread at roughly 4:55 PM MST here in AZ.
Most often we wouldn't be changing all Layers colors in a particular XREF in
At least in my mind. ;0)
Don Reichle
LDT-2K4
XPPro 32bit SP2
news:5569636@discussion.autodesk.com...
>> "MEDIUM"?
>A good gauge to se if the User uses "Quick Select".
Which she answered correctly.
>nice question.
>although, osnap tracking is a less archaic way to accomplish the same
>thing...
Well, perhaps for some people. I think Osnap Tracking completely sucks,
myself.
But it was weird enough that I figured it would throw someone, and I was
right.
>This answer could be an AU topic .
She actually did give the right answer I was looking form, which was to use
Layer 0 and color Bylayer.
>> 13/256", what do you do?
>Label yourself a "deconstructionist", and cop an attitude?
Perhaps.
>good question.
>I assume Dim Aligned, and rotate UCS are acceptable answers?
I was really looking for UCS. I think Dim Aligned dimensions are next to
useless
because of how they behave, and wanted to see if she knew that.
>good question.
>people should know this.
She had no clue - never saw it before.
>good question
Properties 🙂
or Pedit Close.
It's important because so much depends on closed polylines, and I had a rash
of
incidents last week where hatching failed because people weren't clocing
their
plines.
>not average USER fodder, IMO.
Again, wanted to see what she knew. If she did, great, if not, no biggie.
without
>OPTIONS...
Yip
Matt
Message 152 of 256
That is a side effect, true; but only for On/Off. It might make sense to
re-examine the use of Layer On and Off, instead using Freeze/Thaw.
Of course you know the difference: Where Freeze removes the objects from the
Display List, Off does not, which means turning it on imposes no regen time. But
Freeze is overall more efficient because regens are about instantaneous nowadays
and AutoCAD doesn't ever have to deal with the vectors when frozen.
Thus, I teach my users to use On/Off when you temporarily want to get rid of a
layer (or, more often, to isolate a layer for editing, turning all others off)
and use Freeze/Thaw to control overall visibility on a more or less permanent
basis based on the drawing requirements.
However, look at the context of this particular command example: you usually
make global sweeping changes to layer visibility at one time, to set the layer
status for your working or sheet file. In this context, having things turn on
isn't that much of a goober problem, particularly if you use Freeze/Thaw.
But again - it's not the PARTICULAR command that is in question; it's simply a
matter of testing whether the candidate knows there's the command line and that
it can be used to do neat stuff really fast. I do not care one whit whether the
user thinks this usage is a good idea.
Matt
Message 153 of 256
A good question would have been: "explain the difference between assigning
object properties ByLayer and ByBlock in a block definition." or "what is
the function of layer 0 in block definitions". .
"Warren Trost" wrote in message
news:5571058@discussion.autodesk.com...
I also use linetype BYBLOCK for some linetypes in blocks as well.
"John Mayo" wrote in message
news:5569840@discussion.autodesk.com...
We like By Block as well for some stuff. Other stuff is By Layer.
John Mayo
Project Engineer
Conklin Associates
Ramsey, NJ
Civil 3D 2007, LDT 2007, Raster Design 2007
P-IV at 3.5 GHz
2 GB Ram
Nvidea Quadro FX w/ 128 MB Ram
wrote in message news:5569734@discussion.autodesk.com...
BOOOOOOOOOO!
Message 154 of 256
It all depends on what you're objectives are. If you want the block to
maintain the properties of the layers in the block or the layer of insertion
if the block is created on layer 0. Then BYLayer is fine. If you want to
change the properties BYBlock. Then use that.
One example is with LDT you get a lot of plant symbols. For some reason the
linework in those symbols is created on layer 0 but given individual colors.
Of course those colors don't work with my CTB. I can edit the block and
change all of the colors to BYLayer. So they will assume the color of the
layer they are in. But some of the blocks have simple linework -some have
complex. So I want to have the simple ones a color that will plot with a
heavier lineweight than the complex.
Now I know that many will say that doing this violates the "EVERYTHING
BYLAYER" rule and it does. But I don't want to have a Planting-Heavy,
Planting-Medium and Planting-Light layer. I just want a Planting layer. So I
make all the linework BYBlock. So I can change the color of all the lines by
changing the color of the block. I probably shouldn't have said I prefer
BYBlock. I should have said I prefer it in some cases.
news:5571558@discussion.autodesk.com...
Don Reichle
LDT-2K4
XPPro 32bit SP2
jackshield wrote:
> BOOOOOOOOOO!
Message 155 of 256
In question #2 of are you just looking for the line and arc to be drawn
correctly or are you looking to see if the applicant knows how to
automatically draw a tangent arc or line without using any of the LDT
commands?
Allen
"James Maeding" wrote in message
news:5571492@discussion.autodesk.com...
type of questions.
while to c
Matt Stachoni
|>all,
do so
knowledgable
person a
the
|> 1 =
|> 2 =
|> 3 =
|> 4 =
|> 5 =
6 =
|> 7 =
between
|>Overlay and Attach?
13/256",
|>what do you do?
layer
curve?
we
|>Matt
James Maeding
Message 156 of 256
hello?
Does that help?
> parallel
parallel line.
Message 157 of 256
knock knock....
eagle point guru...
news:5572207@discussion.autodesk.com...
hello?
Does that help?
> parallel
parallel line.
Message 158 of 256
I agree with simple. This was more of a problem back when regens were a
real pain with R9 on a 286.
news:5571309@discussion.autodesk.com...
>printings?
layer.
w/muntins
each
Matt
Message 159 of 256
As with any test you are looking to find out if a person has real world
experience and what he know about the program, not to see if he/she is an
expert. Tests are usually designed so that not all questions are going to
be answered. I have a binder I found on the net that is a couple of inches
thick and about 40 lessons that was from a course test. I would hate to
think that any of us would have to have a 95% correctness on this to get
employed but it does show just how much a person is willing to learn on
their own after hours by just reading. As with any test it also has to be
discipline specific as I don't know surveying methods as you may not know
structural ones, etc.
type of questions.
while to c
Matt Stachoni
|>all,
do so
knowledgable
person a
the
|> 1 =
|> 2 =
|> 3 =
|> 4 =
|> 5 =
6 =
|> 7 =
between
|>Overlay and Attach?
13/256",
|>what do you do?
layer
curve?
we
|>Matt
James Maeding
Message 160 of 256
I was checking to see if the user could draw the lines any way they wanted.
Also, to see if they knew what "tangent" meant.
If its a person claiming to be experienced, I watch their keyboard and mouse habits, that gives it away in about 10
seconds.
I never just test though, I talk to the person about various things. You don't want to miss talent.
You also don't want to come up with an opinion totally different than the managers as they are usually good in their
assesment of general skills. Talking is necessary.
Allen Jessup
|>commands?
|>Allen
James Maeding
Administrator Productivity
