• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    CAD Managers
    Distinguished Contributor
    Multiple Profiles
    20 Views, 2 Replies
    02-16-2006 07:18 AM
    I have a need to create a separate profile for a user who has a laptop, basically on and off the network. It seems the easiest way would be to give them 2 desktop icons referencing different profiles. But there is an intimating string of text in the 'target' property of the icon. Does anyone have a reference or example, I would like a better understanding before I get into it.
    Also, any suggestions on keeping duplicate support files up to date. Thanks.
    Please use plain text.
    *James Wedding
    Re: Multiple Profiles
    02-16-2006 09:51 AM in reply to: bthatcher
    After the target, place /p ***** where **** is your profile name. That will
    cause the switch at startup. LDT users are quite use to this trick for
    dealing with Map vs. LDT.
    And I used offline folders with quite a bit of success in just this
    scenario.
    HTH
    James Wedding, P.E.
    Engineered Efficiency, Inc.
    Civil 3D 2006 SP2
    XP Tablet, SP2, 2GHz, 1.5G
    www.eng-eff.com
    www.civil3d.com
    *K
    02-17-2006 08:29 AM in reply to: bthatcher
    bthatcher <> wrote in news:5088118@discussion.autodesk.com:
    > better understanding before I get into it. Also, any suggestions on
    Or you can replicate your netork drives:
    subst j: c:\j
    subst i: c:\i
    Cteate a .bat and modify the above and run before starting cad.
