CAD Managers
*Matt Stachoni
Message 11 of 14 (622 Views)
Re: Moving to another building...
10-02-2006 12:29 PM in reply to: eviele
On Mon, 2 Oct 2006 17:15:37 +0000, pkirill wrote:
>Granted - after reading Larry's post I'm reminded that this will only work
>when relocating a device. It is no help when replacing a device with another
>because of driver issues. That's when the generic naming is handy - but you
>still need to recreate the pc3...
Yes, but in most cases, ports are set once and done with. There's usually never
a need to change the IP address of a plotter or printer. It's more likely that
you replace dead plotter A with just slightly less dead plotter B, which means
you have to rebuild the PC3 from scratch.
Which is why I asked the question, since I've had to do this many times in the
past.
Matt
mstachoni@comcast.net
mstachoni@bhhtait.com
*pkirill
Message 12 of 14 (622 Views)
10-02-2006 01:41 PM in reply to: eviele
"Yes, but in most cases, ports are set once and done with. There's usually
never
a need to change the IP address of a plotter or printer."
To be sure - Unless they are moving and unless they used UNC paths instead
of IP's and the UNC is changing (ie new/different server)
"Matt Stachoni" wrote in message
news:5347858@discussion.autodesk.com...
>another
never
that
means
the
past.
Matt
Distinguished Contributor
cedwards
Message 13 of 14 (622 Views)
10-12-2006 01:56 PM in reply to: eviele
I would fully educate the IT Director on all the possible nuances, and hold him 100% responsible for the outcome.
lsimms1
Message 14 of 14 (559 Views)
10-03-2012 11:25 AM in reply to: eviele
I hope your IT person is not going to rename the server drives.
If so, x-refs, and data shortcuts will need to be repointed.
Not to mention the shared program settings (template, plot settings, etc.) for each computer will need to be repointed.
You are not logged in.
Announcements
Manufacturing CAD & IT Manager Resource
Additional information for installing, licensing & deploying Inventor, the Product Design Suites and Factory Design Suites.
Need installation help?
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
