CAD Managers
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
*Matt Stachoni
Re: Moving to another building.. .
Options
- Highlight
- Email to a Friend
10-02-2006 12:29 PM in reply to:
eviele
On Mon, 2 Oct 2006 17:15:37 +0000, pkirill wrote:
>Granted - after reading Larry's post I'm reminded that this will only work
>when relocating a device. It is no help when replacing a device with another
>because of driver issues. That's when the generic naming is handy - but you
>still need to recreate the pc3...
Yes, but in most cases, ports are set once and done with. There's usually never
a need to change the IP address of a plotter or printer. It's more likely that
you replace dead plotter A with just slightly less dead plotter B, which means
you have to rebuild the PC3 from scratch.
Which is why I asked the question, since I've had to do this many times in the
past.
Matt
mstachoni@comcast.net
mstachoni@bhhtait.com
past.
Matt
*pkirill
Options
- Highlight
- Email to a Friend
10-02-2006 01:41 PM in reply to:
eviele
"Yes, but in most cases, ports are set once and done with. There's usually
never
a need to change the IP address of a plotter or printer."
To be sure - Unless they are moving and unless they used UNC paths instead
of IP's and the UNC is changing (ie new/different server)
"Matt Stachoni" wrote in message
news:5347858@discussion.autodesk.com...
>another
never
that
means
the
past.
Matt
never
"Matt Stachoni"
>another
never
that
means
the
past.
Matt
Options
- Highlight
- Email to a Friend
10-12-2006 01:56 PM in reply to:
eviele
I would fully educate the IT Director on all the possible nuances, and hold him 100% responsible for the outcome.
Options
- Highlight
- Email to a Friend
10-03-2012 11:25 AM in reply to:
eviele
I hope your IT person is not going to rename the server drives.
If so, x-refs, and data shortcuts will need to be repointed.
Not to mention the shared program settings (template, plot settings, etc.) for each computer will need to be repointed.
