• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    CAD Managers
    *Matt Stachoni
    Re: Moving to another building...
    10-02-2006 12:29 PM in reply to: eviele
    On Mon, 2 Oct 2006 17:15:37 +0000, pkirill wrote:
    >Granted - after reading Larry's post I'm reminded that this will only work
    >when relocating a device. It is no help when replacing a device with another
    >because of driver issues. That's when the generic naming is handy - but you
    >still need to recreate the pc3...
    Yes, but in most cases, ports are set once and done with. There's usually never
    a need to change the IP address of a plotter or printer. It's more likely that
    you replace dead plotter A with just slightly less dead plotter B, which means
    you have to rebuild the PC3 from scratch.
    Which is why I asked the question, since I've had to do this many times in the
    past.
    Matt
    mstachoni@comcast.net
    mstachoni@bhhtait.com
    Please use plain text.
    *pkirill
    10-02-2006 01:41 PM in reply to: eviele
    "Yes, but in most cases, ports are set once and done with. There's usually
    never
    a need to change the IP address of a plotter or printer."
    To be sure - Unless they are moving and unless they used UNC paths instead
    of IP's and the UNC is changing (ie new/different server)
    "Matt Stachoni" wrote in message
    news:5347858@discussion.autodesk.com...
    >another
    never
    that
    means
    the
    past.
    Matt
    Distinguished Contributor
    10-12-2006 01:56 PM in reply to: eviele
    I would fully educate the IT Director on all the possible nuances, and hold him 100% responsible for the outcome.
    10-03-2012 11:25 AM in reply to: eviele
    I hope your IT person is not going to rename the server drives.
    If so, x-refs, and data shortcuts will need to be repointed.
    Not to mention the shared program settings (template, plot settings, etc.) for each computer will need to be repointed.
