• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    CAD Managers
    Monitor Selection for AutoCAD 2013
    2174 Views, 13 Replies
    01-15-2013 11:32 AM
    I am trying to upgrade our monitors and would appreciate some feedback on what others are using. Is anyone using a 30" or larger display? Or is it better to go with two 24" or 27" displays? Any and all suggestions are appreciated. Thanks in advace for your comments.
    Please use plain text.
    *Expert Elite*
    Charles_Shade
    Re: Monitor Selection for AutoCAD 2013
    01-15-2013 12:16 PM in reply to: AutoCUD
    32" Sharp Aquos and (2) 24" Asus 16:9 Monitors.
    More is better!
    DVI or HDMI connections only. VGA is not clear enough.
    Regards, Charles Shade            Win8 FAQ
    CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
      Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
    Distinguished Contributor
    Wanderer-MOTD
    01-16-2013 11:08 AM in reply to: AutoCUD
    My shared workstations have larger monitors (32" and 50" iirc), and my own workstation has 2 - 20".
    I do like the larger monitor, it is good for viewing scans of prints. But, on the days I have to work on one of them for an extended period, I find that I do miss the application separation I typically enjoy with two separate monitors.
    Melanie Perry
    ***not all who wander are lost***
    http://AUGI.com/Surveys
    http://MistressOfTheDorkness.blogspot.com
    My defunct profiles:
    http://forums.autodesk.com/t5/user/viewprofilepage/user-id/651859
    http://forums.autodesk.com/t5/user/viewprofilepage/user-id/644095
    *Expert Elite*
    dgorsman
    01-16-2013 01:09 PM in reply to: AutoCUD
    Dual monitors are best.  Even with the "extra" space a widescreen monitor provides, its not enough with all the extra palettes, torn-off ribbon panels, PDF reference files, and the like.  Something else to keep in mind is monitor sizes are corner-corner, so a 16:9 28" monitor may actually be *shorter* than a 24" 4:3 monitor.  Thats one of the reasons I prefer the older, non-widescreen monitors.  That, and a pair of them extends to the limit of my readable field of view.  Anything beyond that isn't useful for much.
    Adopt. Adapt. Overcome. Or be overcome.
    *Expert Elite*
    rkmcswain
    01-17-2013 11:03 AM in reply to: AutoCUD
    IMO - 2-24" is nice, 2-27" if you can swing the price difference.
    We have some of both. The 24" is ±236 sq. in., while the 27" is ±306 sq. in. --- quite a difference.
    *Expert Elite*
    rkmcswain
    01-17-2013 11:05 AM in reply to: Wanderer-MOTD
    50"? Nice.
    Is this a TV or a monitor?
    Wanderer-MOTD
    01-17-2013 11:16 AM in reply to: rkmcswain
    It's a monitor. The largest one IT had. Once we went over that size, it would be tvs from the av department and they were much more spendy.
    ~checking my project folder~ Ah, my bad, looks like my memory did not serve me well...  32" was correct, but, the other was actually a 42".
    Ah, according to the original proposal I received from the admin overseeing that space, she wanted a 50" or 60" tv and I had to make her settle for a 42" monitor instead. lol. I'm so mean.
    Melanie Perry
    02-11-2013 02:56 AM in reply to: Wanderer-MOTD
    What sort of resolutions are people using?
    I've currently got a pair of 20" Dells on my desk, 1200x1600 which I consider a good setup. Hoever given the abundance of widescreens formatted for 1080 lines I'm curious as to how folks find this reduction in vertical space.
    ACad, MEP, 3DS Max
    Windows 7x64
    X5482 @3.2Ghz 8Gb Ram
    Quadro FX1700
    *Expert Elite*
    Charles_Shade
    02-11-2013 05:33 AM in reply to: GilesPhillips
    1366x768  32" Sharp Aquos
    1920x1080 Asus 24" Monitor
    All are widescreen 16:9 I believe
    *Expert Elite*
    rkmcswain
    02-11-2013 08:35 AM in reply to: GilesPhillips
    1920 x 1080
