• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    CAD Managers
    Member
    Managing a Large Block Library
    225 Views, 6 Replies
    01-30-2009 03:50 PM
    HI all, I need some input/opinions on the best way to manage a large block/standard details library. I am looking for how others sort/manage their libraries and how they used from within Cadd.
    All input and suggestions are welcome.
    Thanks in advance.
    Ryan
    Please use plain text.
    *Dean Saadallah
    Re: Managing a Large Block Library
    01-31-2009 07:32 PM in reply to: RyanRoberts4500
    How are they organized/stored now for your access?
    You may be able to just tweak what you have for an optimum
    solution.
    *Matt Stachoni
    02-02-2009 06:07 AM in reply to: RyanRoberts4500
    On Fri, 30 Jan 2009 23:50:57 +0000, RyanRoberts4500 <> wrote:
    >HI all, I need some input/opinions on the best way to manage a large block/standard details library. I am looking for how others sort/manage their libraries and how they used from within Cadd. All input and suggestions are welcome. Thanks in advance. Ryan
    There are literally tens of ways to manage block libraries; each has their
    advantages and disadvantages.
    The easiest - from a managerial perspective - is simply to create a folder on
    your server, and create a DWG file for each type of blocks you use. Since we are
    an Architectural/Interiors firm, our block library uses drawing files for each
    of the MasterSpec divisisions, e.g. my "Div05-Metals.dwg" has blocks for steel
    shapes, metal studs, and so on. This is in addition to generic blocks like
    Annotation, Formatting (title blocks), Entourage (for presentations) and so on.
    Once these library drawings are created, you can use Design Center to insert
    them into your drawings, or create Tool Palettes for each of the blocks. You can
    easily create a single palette of all of the blocks in the drawing via Design
    Center.
    Once you create Palettes, you could then create Catalogs and Categories on your
    server, copy your Palettes to the Catalogs/Categories, then iDrop them back to
    user's workspaces for their access.
    Besides Design Center and Tool Palettes, you are left to implementing old-skool
    methods like slide libraries, pulldown menus, and VLISP code, or a combination
    of all three.
    I personally went from a highly customized solution of pulldown menus and VLISP
    code to using Content Browser and Tool Palettes, which worked out GREAT.
    Matt
    matt@stachoni.com
    Distinguished Contributor
    02-02-2009 09:06 AM in reply to: RyanRoberts4500
    I agree with Matt (again)... At first I didn't like the MasterSpec divisions, thought it was way too much, confusing, and far too many places to look for a block, but after a few months of use it's ok. we do group our block in a specific drawings so it's easy to find. I've set up pull down menus to access this directory via ACAD Design Center, so if someone needs a sink, the click on the plumbing fixtures pull down menu for sinks, and the DC will open and display all the blocks in the "Sinks" dwg.
    Paul Caruthers
    Bessolo Design Group.
    Member
    02-02-2009 12:34 PM in reply to: RyanRoberts4500
    Thanks all for repling so far I appreicate it very much. We currnetly have nothing setup or in place as we are just starting to get all this together with the new company.
    We were thinking that using the Master Spec divisions would be the way to go but we were lookign for opinions and we got some.
    I would like to hear from anyone that sorts the libraries differently than using the Master Spec.
    Thanks again for all that responded so far.
    Ryan
    02-02-2009 01:56 PM in reply to: RyanRoberts4500
    You could use my boss's method. Dump everything in one directory, give the files some cryptic name and spend 4 hours looking for something.
    *neilw
    02-03-2009 07:20 AM in reply to: RyanRoberts4500
    Another approach is to store multiple blocks in a
    single DWG. This makes it easy to create tool palettes with pre-defined layer
    settings for the blocks. The tool palette will use the layer the blocks are
    stored on when inserted into new drawings. This makes it much easier to manage
    layer standards and other types of edits when necessary.
    Each block file becomes a block library for
    varous disciplines or whatever other way you want to classify
    them.
