• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    CAD Managers
    Distinguished Contributor
    andrew.warren
    Licensesing Management Without SAM?
    262 Views, 7 Replies
    04-18-2012 06:45 AM
    What does everyone use now that SAM Reports is gone? I just changed jobs and took over as CAD / License Manager and to my suprise SAM Reports Lite has been discontinued for Free from Autodesk. We are adding people like crazy and I need to monitor the usage pretty closely to see when we need to add seats. Also it seems a couple users are given two seats for some reason but I can't tell for sure without a good reporting tool. Any ideas?
    Andy Warren
    BCDesign@bellsouth.net
    Please use plain text.
    DarrenP
    Re: Licensesing Management Without SAM?
    04-18-2012 10:59 AM in reply to: andrew.warren
    this is the only tool that i have found: http://www.jtbworld.com/jtbflexreport/index.htm
    andrew.warren
    Re: Licensing Management Without SAM?
    04-18-2012 11:07 AM in reply to: DarrenP
    Thanks I have already sent off for a quote and trial just wanted to see if anyone else uses anything else. I can't believe Autodesk would not provide something with LMTools to see when we are bumping our heads on the limits. Seems like it would help with sales. If we see we are hitting the limit more than x number of days in a row then we buy more seats to accommodate that. But as a CAD Manager if I can't see it I assume it is OK. Yes users will complain but when do they not.
    Andy Warren
    TravisNave
    04-19-2012 08:13 AM in reply to: andrew.warren
    Let us know how you like it.  Jimmy is a great asset to this community and I have been recommending his product for quite awhile.  He has a freeware classified here on the boards too:
    http://forums.autodesk.com/t5/Classifieds/JTB-FlexReport-1-0-released-as-freeware-FlexNet-HTML-repor...
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Valued Contributor
    05-02-2012 07:08 AM in reply to: TravisNave
    Seems like you may have found an alternative but I just wanted to let you know I just downloaded SAM reports from autodesk last week so I don't think it's discontinued... it worked for me.
    Civil 3D 2013 sp1
    Windows 7 x 64, 8 GB
    Intel i7-2600 @ 3.40 GHz
    TravisNave
    05-02-2012 08:29 AM in reply to: nelsons
    It is still available and technically still works, but the product itself has been deprecated and laid to rest.  I still use it occasionally but it is not a viable solution moving forward.
    Travis Nave
    Valued Contributor
    05-02-2012 08:40 AM in reply to: TravisNave
    Good to know, thanks. I've just spent the last few hours testing it out and I must admit I'm not too impressed.  Up until last week I never really felt the need for this type of software (we only have a handful of licenses to begin with) but I was surprised to find nothing was built into LMtools when I started my research.  I guess the search continues. :manfrustrated:
    Civil 3D 2013 sp1
    warrenandy
    05-02-2012 11:04 AM in reply to: nelsons
    So far I really like the JTB stuff it gives some good reports. Took a little getting use to to figure out what does what but hey we are CAD people right? Whats more complex than Autodesk's porfolio... It is pretty smooth now that I set up Feature Groups and figured out how I want stuff parsed out. It is definitely worth trying out. I wish it was free with LMTools, but it is cheap enough I think I can get it still...
    Andrew Warren
    CAD & Data Management Specialist
    Bridgestone Americas Tire Operations
    andrew.warren@bellsouth.net
