Autodesk Technology Managers Forum
Share your knowledge, ask questions, and engage with fellow CAD/BIM Managers.
AKSBrettHartley
568 Views, 2 Replies
LM Tools Window
I looked for a networking wishlist to post this, but didn't see it, so I apologize to all of you who don't need to listen to me whine.
Would it kill the makers of LM Tools to make the flippin' window bigger so I didn't have to paste out the server status into notepad?  I mean, I know they're putting all their imense resources into improving the general interface, and it shows,,, but seriously, is everbody still rockin' the 15 inch monitor and space is still at a premium.
Thanks for listening.
Rand Waltz
2 REPLIES 2
dgorsman
in reply to: AKSBrettHartley
Kinda-sorta.  Our designers have the large monitors, the server rooms have our few remaining mini-size monitors.  Not that they get used that often, LMTOOLs are usually run through remote.  But monster size dialogs are problematic when working off one of those server terminals.
You could run it as a command line and pipe it into a text file. 😄
There's a web-based version you can try too if you wanna check my sig-line.
Autodesk Forums:
Administrator Productivity
