Does anyone know anything about the new Inventory Advisor Tool?
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=10243574
I downloaded and installed it, but it is apparently a trial. According to the documentation, you get the unlock code from an Autodesk rep., but it makes no mention of where to request the code and I cannot find anything in the software.
"Upon launching the application for the first time, you will be prompted to input a user name and unlock code. An Autodesk representative will provide this information to you"
http://images.autodesk.com/adsk/files/aia_quick_start_guide0.pdf
Is this a "free" tool (included in our subscription) that we need to obtain a code for via our reseller?
Solved by DarrenP. Go to Solution.
I'm looking for :
- Product name (OK)
- Version (OK but I don't need)
- Location (not found)
- Sérial number (not found)
- Install Type (Standamone or Network : not found)
- Language (Not found)
I can't use SpiceWork to inventory Autodesk software with missing informations.
JR
Hi everybody,
Happy new year 2013.
I hope it'll be better than 2012!!!
I'm looking for new release of AIA able to inventory all autodesk product including 2013 and Suites 2013.
The old release AIA 3.95 can only sacn Autodesk products prior to 2012.
I would like to know if Autodesk will develop a new version and when will it be available?
JR
i don't think they are offering this anymore
they would have released it by now
DarrenP
I'd tested NIA4 (build 4.0.2101). It seems able to scan now Autodesk 2013 products;
JR
What does 1 mean, is it independent and does it mean alone?
@Anonymouswrote:Hi, I m using Autodesk Inventory Advisor tool to get the numbers of license already used on my LAN, and that's work great, but I want to get the installation type too, and this field only shows some numbers, 0,1,2,3, I'm looking for some information about this, what does it means each number? Please if someone knows something about it, reply me, or maybe some post or manual to get more info about the tool.
Thanks and Regards
2009 and older would be standalone, 2010-2016 would be network.
Is this tool is free of cost , If a customer install this for Auditing Autodesk Application once in a month or two will be complaince or not.
this is not a free application anymore
DarrenP
i also don't believe Autodesk uses this tool anymore
DarrenP
