• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    CAD Managers
    Re: Inventory Advisor Tool
    08-26-2012 07:25 PM in reply to: ruud.heurter
    Hi, Thanks for your alerte mail. I still not found a good answer for my request below : -------------------------- Hi every body, I tested Autodesk Inventory Advisor (AIA_3.95.1778.zip) to scan my computer that contains Autodesk 2012 and 2013 products. I get a report from AIA, it only contains Autodesk 2012 product, no trace about Autodesk 2013 products installation. Is AIA able to identify the Autodesk 2013 products ? exist some patch to solve this trouble ? ------------------------- JR CHHOR jean.chhor@insight.com
    Please use plain text.
    Member
    ruud.heurter
    08-27-2012 12:14 AM in reply to: jrchh1
    I received some additional information
    3 refers to  a network license
    1 and 2 refer to standalone licenses
    0 refers to a newer license where the type is stored in another file. Autodesk’s tools can determine what this is.
    when you go into the Autodesk Inventory Advisor to Reports and you run the "by software" report and not the serial number you will find the 2013 installations. But no serialnumbers are found in this reports
    08-27-2012 12:36 AM in reply to: jrchh1
    Hi
    Thanks for your anwser.
    So AIA is not fully exploited.
    During the inventory, you need the serial number, the name and version of the product and the type of installation....
    When Autodesk will release a workable version?
    Regards
    JR
    Member
    ruud.heurter
    08-27-2012 12:52 AM in reply to: jrchh1
    The problem with the tool is that autodesk provides this as just a tool to help you getting inventories from your assets.
    It ofcourse says nothing about usage of your software, I have not found anything about an update of the software so that R 2013 will be found.
    I sent a request to ClearApps LLC the owner of the inventory tool. When I recieve there answer I will let you know
    09-04-2012 05:57 AM in reply to: jrchh1
    AIA 4 beta 'll coming soon.
    http://blog.clearapps.com/releases/network-inventory-advisor-4-beta/
    I hope it solves all problems
    - Detection Autodesk 2013 products
    - Type of installation ...
    JR
    09-06-2012 12:37 AM in reply to: jrchh1
    I tested NIA 4 beta it detects Autodesk 2013 products but can not find serial number and installation.type.
    JR
    Employee
    09-12-2012 04:04 AM in reply to: jrchh1
    2013 product detection is not available at this time. It is forthcoming.
    10-23-2012 02:50 AM in reply to: baker1975
    Other than Inventory advisor 4 or Asset locator who does not work with Autodesk 2013 products, do you know another tool to make an correct inventory of Autodesk products?
    JR
    Employee
    10-23-2012 06:40 AM in reply to: jrchh1
    If you are just looking for installation data (e.g. Add or Remove Programs), pretty much any software asset management tool on the planet can show you that data. The easiest way is to search on the Publisher of "Autodesk*". Note the wildcard at the end. That will ensure you pick up any listed as "Autodesk, Inc." or similar variation. This will show you absolutely everything installed, including plug-ins, service packs, etc. Spiceworks is one of the more common tools out there that can do this and it's free. Scott Baker Licensing Technical Specialist WW Engineering, Natural Resources, and Infrastructure Sales Direct 618.988.2050 Mobile 618.727.4127 [Description: Description: Adsk_logo_4_sig_v03_crop.gif]
    10-31-2012 05:30 AM in reply to: jrchh1
    Hi baker975,
    Thanks for your answer.
    I've tested Spiceworks to scan Autodesk Software.
    Spicework is not a tool to make an inventory for Autodesk products .
    Results in reporting are not really usable.
    JR
