• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    CAD Managers
    New Member
    Inventor 2012 crashes in Windows 8 Release Preview Build 8400
    467 Views, 3 Replies
    06-30-2012 03:54 AM
    I just upgraded to Windows 8 Release Preview Build 8400. I am facing problem of Inventor crashing frequently. Does any one have come across such situation, and does any one have a solution to this.
    Thanks in advance,
    Samir
    Please use plain text.
    Distinguished Contributor
    Re: Inventor 2012 crashes in Windows 8 Release Preview Build 8400
    07-01-2012 04:44 PM in reply to: shyamplastic
    go back to a supported operating system
    TravisNave
    07-02-2012 09:13 AM in reply to: shyamplastic
    Windows 8 is still a beta product and is not supported for use in actual production environments.  Your Autodesk product is not supported on this.
    That being said, in most cases, Inventor crashes are due to video card drivers. So, you might consider using a WHQL certified video driver for Windows 7, if you can find one that works.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    DarrenP
    07-02-2012 12:08 PM in reply to: TravisNave
    or use one certified for windows 8
    both nvidia and amd have released beta drivers for windows 8
