I hope some one can help me here. (not sure if this is an Acad or an MEP problem.) We recently had a seat of Acad MEP 2012 go "corrupt" on us. It appears that the DB code that is usually suppressed, now shows up in the command line. (see attached). We have repaired, reinstalled, even unistalled and reinstalled - it won't stop writing hundered of lines of "database info" onto the command line at every command, or even just moving the mouse around... (I do seem to remember some variable or command line switch, from way back, that the programmers used so they could to see the code scroll by...)
It has also caused issues with the MEP portion of the program (i.e. - won't remember routing preferences, won't keep sloped pipe connected,etc...) So I don't know what is the cause & what is the effect in this situation... or how to fix any of it!!
Bueller? Bueller...Anybody?
you say you uninstalled and reinstalled -- but did you do a 'clean' uninstall that takes everything acad related off the machine?
this should help...
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=10243968&linkID=9240617
It's on the AEC tab of the OPTIONS dialog box. Turn off debugging.
Mike Caruso
http://civildisobedience3d.wordpress.com/
