• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • CAD Managers
    *Esquivel, Luis
    Have anyone one is using the system projectmates or am workflow?
    80 Views, 8 Replies
    12-21-2000 01:29 AM
    We would like to hear if someone is using or know about projectmates from:
    www.projectmates.com this is supposedly for online project management for
    busy project managers.
    Also how about AM Meridian or AM Workflow from cyco
    We are in the process to buy something like this, in order to have control
    with our projects and consultants.
    Any thoughts or feedback is welcome
    Luis Esquivel
    M+C Architects, San Diego, CA
    Please use plain text.
    *Kyriacou, Chris
    Re: Have anyone one is using the system projectmates or am workflow?
    12-21-2000 02:03 AM in reply to: *Esquivel, Luis
    Luis,
    I used to Install, Customise and
    Configure Document Management Systems, mainly:
    AM Workflow
    AM Meridian
    Motiva Designgroup/eChange (went
    bust)
    Both AM Meridian and Workflow have
    some limited Internet/Intranet facilities for data sharing, however, for full
    use require a client to be installed on each machine.
    Workflow is for Home to Small Office
    users, and is highly configurable using either BaseLISP or VB (or both!) runs
    using a flat DBIV dB, relatively cheap. Max amount of docs ~15,000
    Meridian is for small to medium
    sized firms can be used with it's own proprietry dB or hooked into a SQL 7
    server. Customisation is utilised using VB/VC++ with either Server or Client
    application 'hooks'. More expensive than Workflow!
    Max. amount of docs ~60,000
    (250,000+ with SQL).
    Either products offer Project life
    cycle management, ACAD block libraries, workflow, revision control, security,
    and with Meridian your docs are stored in a 'secure' vault (utilised thru drive
    mapping on the client PC's).
    Neither product will fit
    your needs 'out-of-the-box' and will need customisation in some form or another,
    speaking from a customisation point of view I recommend you get a dealer to come
    in and analyse your business processes and work out how many days' customisation
    you will need for a fully fledged
    automated
    syste
    m. A lot of customers I know that
    have installed systems themselves usually
    underspec the initial installations and have severe problems several months down
    the
    line.
    If you need any forther help or if
    anyone has any questions I would be glad to offer assistance.
    Chris Kyriacou
    Technical Director
    Avatar Consortium (UK)
    Ltd.
    size=2>> We would like to hear if someone is using or know about projectmates
    size=2>www.projectmates.com
    > busy project
    managers.
    cyco
    to have control
    > Any
    > Luis Esquivel
    > M+C
    *Esquivel, Luis
    Re:
    12-21-2000 02:34 AM in reply to: *Esquivel, Luis
    Thank you Chris for your input, we will still try to look for more options
    before we make a final decision, I'm glad that you enlighten us in the right
    direction.
    Happy holidays,
    Luis Esquivel
    *Ross, Kevin
    12-21-2000 09:05 PM in reply to: *Esquivel, Luis
    We use AM Workflow for 70,000+ drawings. With this large of a database it
    often takes 2 hours to re-index and re-pack for maintenance during which
    time all users must be off the system. We generally do this once a week in
    the evening or on the weekend. The product is written specifically for
    AutoCAD so it integrates very well (It will manage other CAD files as well).
    I've found that I get more assistance from the Cyco messageboards than from
    the dealer regarding customization. You should download and read the User
    and Administrator training guides from their web site.
    http://www.cyco.com/Homepage/Home.nsf/P30?OpenPage
    Good luck,
    Kevin
    Luis Esquivel wrote in message
    news:01F8FBCB114218DF1794EEA66D28C417@in.WebX.SaUCah8kaAW...
    > Luis Esquivel
    *Kyriacou, Chris
    Re:
    12-21-2000 09:09 PM in reply to: *Esquivel, Luis
    Kevin,
    In your case it may be worth considering the upgrade to Meridian with a sql
    server... They have a Workflow to Meridian upgrade tool available that may
    help you transfer all docs etc. to the new system...
    If you like, I could have a look into how thorough this utility is?
    Chris Kyriacou
    "Kevin Ross" wrote in message
    news:FCA2F89F3FC086410BBD975B32F5C6B4@in.WebX.SaUCah8kaAW...
    well).
    from
    > Good luck,
    > Kevin
    for
    control
    > > Luis Esquivel
    *Ross, Kevin
    Re:
    12-22-2000 07:09 PM in reply to: *Esquivel, Luis
    Chris,
    Thanks for the offer. Please let me know what you find. We currently have 20
    seats of Workflow. During the last year I was able to get our company to
    spend a great deal of cash on system upgrades so they might not swallow a
    new upgrade until 2002! Will the upgrade you refer to improve the time it
    takes to search the database? Currently it takes 8-10 minutes to run a
    search through 70k+ documents.
    Kevin
    Chris Kyriacou wrote in message
    news:smileyvery-happy:34C7F0EE130CA9F8FD8CD2AEB1CB147@in.WebX.SaUCah8kaAW...
    > Kevin,
    sql
    > Regards,
    > Chris Kyriacou
    *Esquivel, Luis
    Re:
    12-27-2000 12:07 AM in reply to: *Esquivel, Luis
    Thank you Kevin
    Luis
    Kevin Ross wrote in message ...
    *nathan, stuart
    01-02-2001 07:23 AM in reply to: *Esquivel, Luis
    I've held back for nearly six months now, but today I'm taking the plunge.
    If you want to do everything you ask and more, such as job costings,
    timesheets etc. with a product that needs NO customisation, then could you
    have a look at Office Manager
    Stuart Nathan @
    http://www.dwgoffice.com
    *Esquivel, Luis
    Re:
    01-02-2001 08:17 AM in reply to: *Esquivel, Luis
    Thank you for your response,
    Stuart, How about protection of our drawings, partial access from our
    consultants, and is this software compatible with standards used here in
    USA?
    Luis Esquivel
    stuart nathan wrote in message
    <847EBD08C5F56075B72CABA8E04E821C@in.WebX.SaUCah8kaAW>...
    >Stuart Nathan @
