Could NCOPY be of use in this situation?
Personally I've used a variation of what Elvis described - all my hatching
is done in a Separate dwg. Since Draworder quibbles over Hatch Entities - in
my experience I mean.
I then set DRAWORDER as necessary for the Hatching (most times it's Back),
in that dwg.
I then use XREF in the Plot dwg for this Hatch dwg, and when I then set the
Draworder to Back on the XREF, it retains that setting from then on.
I noticed that in 2Ki and 2K2 the Hatch's would not cooperate with Draworder
unless done through the manner I just described.
Just an alternative thought.
Don Reichle
"The only thing worse
than training your staff,
and having them leave is -
not training your staff,
and having them stay."
Courtesy Graphics Solution Providers
LDT-2K4
AMD Athlon 64 3200+ 2.2GHz
XPPro 32bit SP2
1GB RAM
Nvidia GeForce FX 5200 128MB
WD 36GB Raptor
"Jason Hickey" wrote in message
news:5141972@discussion.autodesk.com...
Elvis Landaverde wrote:
> I remember the computer crashing when you do that on ACAD2002, but on 2004
> and 2005 it was possible to do it. (in this case, structural drawings
> trying
> to show the cmu walls on top of the slab). so now is a no-no.......?
It's always been a no-no. Even if it worked, it was a no-no. Bad
juju there, mon.
Your best idea is to trace your boundary and hatch that.
Jason Hickey
http://beneaththelines.blogspot.com
