ATI has a cleaner for their drivers and software on their website. Seems
to do the job pretty well. But I know what you mean about stupid
compatibility issues. I had an ATI video card and an ATI TV card. Never
could get them to work right together. But the tv card worked fine on
another computer, and a different tv card worked fine on the computer
with the ATI video card.
Brian Allen wrote:
> I've recently run across a problem like this myself. And I'm the IT
> guy. So, first question: Same brand card? Going from an ATI to and
> ATI or NVidia ro NVidia? Believe it or not, this causes more problems
> than changing brands.
> I went from an ATI X1600 at home to an ATI X1650 (don't ask why change
> for that...not really my choice) and the X1650 will not load drivers
> or diplay properly
> I will soon be installing my new card at home again, but have a
> procedure that needs to be followed.
> Uninstall all video drivers for the existing card.
> Shut Down
> Remove old card
> Install new card
> Disconnect from internet
> Boot into safe mode
> If you have the option, cancel the "New Hardware Found Wizard" if it
> comes up.
> Run 'Driver Cleaner' program - This will remove all graphics drivers
> from your system (not like the control panel since it leaves crap
> everywhere)
> Shutdown when done
> Reconnect to the internet
> Boot
> Follow instructions for new card. Some say cancel the "New Hardware
> Found" and run their program, others say let it run and use those
> drivers.
> Seems like a REAL PITA, but after researching several boards, this
> appears to be the best solution. What is typically happening is the
> system (Windows) is detecting parts of the other drivers still on your
> system and it decides to try to use those. This causes huge problems.
> Have your IT guys check out Driver Cleaner (latest version is $9.99)
> at www.drivercleaner.net. Or you can get an older version that is
> supposed to work fine at
> http://downloads.guru3d.com/downloadget.php?id=745&file=7&evp=61b47f98de384e3d2b34b0207934f958
> Good luck.
> On Thu, 10 Jan 2008 19:30:20 +0000, Matt Stachoni
> wrote:
>> On Thu, 10 Jan 2008 16:35:22 +0000, artsart <> wrote:
>>> I'm still waiting and thinking they are made of jello not the steely types I would have imagined. I wish I could go down there and get the card and give it a go by myself but they are like "nazis" down there with their stuff. That's what we call them too the "IT Nazis" and the manager is nicknamed "Little Hitler".
>> Remember that Hitler couldn't install a graphics card to save his life either.
>> Always taking his PC to CompUSA to get fixed.
>> Matt
>> mstachoni@verizon.net
>> mstachoni@bhhtait.com
