• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    CAD Managers
    New Member
    Global Width of a polyline
    11444 Views, 14 Replies
    10-16-2009 02:50 AM
    I am very much a beginner with AutoCAD and the majority of what I'm doing at the moment is tracing rubbersheeted paper maps with polylines. My problem is that my polyline tool has somehow gotten set to a global width of 1.9 (approx.) and is so wide that I can't see what I'm tracing. I have to change it back to 0 in the properties box, but by then I can't continue drawing the same polyline. Polyline is the only tool set to such a thick global width, lines and arcs seem fine.
    So, I want to figure out how to set the global width for polylines back to 0 as a default.
    Many thanks,
    Lacey
    Please use plain text.
    Re: Global Width of a polyline
    10-16-2009 02:55 AM in reply to: laceysname
    pline
    place your first data point
    then type W
    then set the default width to 0
    all future polylines will now use 0
    New Member
    10-16-2009 03:06 AM in reply to: laceysname
    Thank you! You have solved my problem! Thank you so much for being generous with someone who obviously is rather ignorant as well. I do nearly all of my work in Illustrator, and AutoCAD is very different.
    I have a secondary problem, caused by the first one that maybe you might be able to help with too? I'd be so appreciative. I drew several lines, instead of polylines, because I couldn't see what I was tracing. But, I really need those lines to be joined into polylines. Is there a way to join them together and turn them into a polyline?
    Active Contributor
    10-16-2009 04:52 AM in reply to: laceysname
    PEDIT
    select a line
    convert it to a PLINE
    JOIN all the lines together using PEDIT command
    *Dave Jones
    10-16-2009 07:09 AM in reply to: laceysname
    markdoel wrote:
    > pline
    > then type W
    or do it the easy way and set PLINEWID to 0
    Dave
    DDP
    Distinguished Contributor
    10-16-2009 11:04 AM in reply to: laceysname
    If you have trouble joining line segments, it means the end points are not at the same x,y,z in space. Sometimes its not very obvious, so make sure your end points are at the same point.
    Reid
    New Member
    victoria_yoncheva
    01-07-2011 10:20 AM in reply to: omc-usnr
    Hey guys!
    1. I have a problem with the global width of a polyline. At first, when I set global width, the polyline became with the width I wanted it to be, but a day after when I opened my .dwg, the width itself was gone - there were only the contours of the polyline with the global width, but the polyline wasn't thick, it was empty. How can I fix this problem? I want to see the polyline with its global width the normal way.. Here is a screenshot of the situation..
    *Expert Elite*
    Charles_Shade
    01-07-2011 11:22 AM in reply to: victoria_yoncheva
    Is your FILLMODE set to 1?
    Please mark any response as "Accept as Solution" if it answers your question.
    _____________________________________________________________
    Regards, Charles Shade             Win8 FAQ
    CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
    Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
    New Member
    07-17-2012 12:36 PM in reply to: Charles_Shade
    Hi! I don´t know how to make the polylines to appear fill. I paste an image of what I´m saying... Miy fillmode is in 1.
    Could anybody help me?
    Thanks!
    New Member
    victoria_yoncheva
    07-19-2012 12:39 AM in reply to: laceysname
    If I'm not wrong, I think I handled the problem with deleting unnessessary things in the drawing. The .dwg file was too heavy and because of that, the global width has gone, and there were only the contours of it. If you haven't anything to delete, try with PURGE command and then PURGE ALL. I hope this can help you!
