f.tagle said the following on 7/19/2006 5:20 PM:
> I need help to change all the text styles to standard with romans as font. Can anyone send me a lisp routine that would
> accomplish the task without the dialog box popping out.
> Thank You Very Much
Is this supposed to be the same question as above?
"change all the text styles to standard with romans as font" doesn't
make sense unless you are wanting to delete all textstyles except
standard and set it's font to ROMANS
Did the answer here not help?
http://forums.augi.com/showthread.php?t=43262
R.K. McSwain
http://rkmcswain.blogspot.com
