CAD Managers
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
FlexLM License Cascade Problem
- Highlight
- Email to a Friend
I'm getting very frustrated with Autodesk's FlexLM licensing and hope someone here can help. So far, our local resellar can't even seem to figure this out.
Although we own several Autodesk products that have this issue, I'll stick with our main priority which is Revit.
We own:
Revit Architecture 2012 - 7 seats
Revit MEP 2012 - 3 seats
Revit Structure 2012 - 2 seats
Autodesk Building Design Suite 2012 - 10 seats
When advised by our reseller to add Revit seats by purchasing the Suite for reasons of cost, we were told that we could install products with a single serial number and the relative product keys and have all the products cascade such that all licenses are available. For example, we should be able to get a maximum of 17 Revit Architecture licenses when that generic serial number was used.
One source told us that using the generic serial number (Revit-specific?), 400-0000000, and the product code would work for all revit versions, but so far it has not, regardless of what media I try, including the download fromt the subscription site.
Any ideas how to do this? Is it possible?
Re: FlexLM License Cascade Problem
- Highlight
- Email to a Friend
it sounds like you want to combine the building suite serial # into the revit architecture serial number?
- Highlight
- Email to a Friend
Correct.
I'll add that we have the same need with 3DS and AutoCAD, for which we have both non-suite and suite seats.
- Highlight
- Email to a Friend
i know there were problems with all the new 2012 suites with regards to cascading
like this one: http://usa.autodesk.com/adsk/servlet/ps/dl/item?si
- Highlight
- Email to a Friend
Darren,
The linked article included this paragraph:
"In order to resolve this issue, install AutoCAD 2012 from the Building Design Suite media using the Building Design Suite 2012 Product Key. AutoCAD with the Building Design Suite Product key will be able to use a license from AutoCAD or the Building Design Suite license packages that are on the license server."
This suggests that using the Suite Serial Number and Product Key will cascade downwards to the non-suite licenses and would likely work for all prducts in the suite. I suppose the only way to know if that works would be to try it and watch the activity on the server.
Thanks.
- Highlight
- Email to a Friend
i would test it on a non production machine if possible
- Highlight
- Email to a Friend
That's what I intend to do. Thanks again.
- Highlight
- Email to a Friend
i would have to do research on your serial number question
i know you can combine serial numbers for revit arch 2012 into another revit arch 2012 serial # on the same sub contract
i never heard of combing serial numbers of revit arch 2012 into a building suite serial number
- Highlight
- Email to a Friend
I found another article that suggested the same process as the one you linked to.
It seems that with 2012 products the process is backwards, with licenses casdading downwards from the suite, as long as the suite package is listed after the stand-alones in the license file, which it is in my file.
I did find that I can use the suite numbers with the downloaded Revit install files.
- Highlight
- Email to a Friend
will have to wait and see if this was fixed with the 2013 suites
