CAD Managers
Active Contributor
riznasp
Message 1 of 9 (644 Views)
Accepted Solution
FILL ISSUE WITH DIMENSION HEADS
644 Views, 8 Replies
01-07-2014 01:12 AM
Dear All,
I have a problem with the dimension's arrow heads "architectural tick". It normally shows as filled but in the drawings it shows without fill (something like a wireframe). I have checked commands like fill, fillmode and display in the option. Could you please tell me what could be the reason.
Riznas
*Expert Elite*
pendean
Message 2 of 9 (617 Views)
Re: FILL ISSUE WITH DIMENSION HEADS
01-07-2014 08:40 AM in reply to: riznasp
SHADEMODE set to 2D? It should be.
Rotated UCS?
Problem limited to one file?
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Active Contributor
riznasp
Message 3 of 9 (595 Views)
01-08-2014 04:09 AM in reply to: pendean
Thanks for your reply,
Shademode, ucs,... are all fine. When i copy the same dimensions to other files it show the same problem. Any other fix?
Riznas
*Expert Elite*
pendean
Message 4 of 9 (551 Views)
01-10-2014 03:44 AM in reply to: riznasp
Post that DWG file here for review.
Active Contributor
riznasp
Message 5 of 9 (531 Views)
01-13-2014 05:33 AM in reply to: pendean
Please see attached cad drawing as requested.
Riznas
*Expert Elite*
pendean
Message 6 of 9 (522 Views)
01-13-2014 01:03 PM in reply to: riznasp
Your UCS is rotated and PLAN is not aligned with it. Setting UCS and PLAN to WORLD seemed to fix the problem for all newly drawn dimensions.
Deifne ALL FINE in youre earlier response?
LIST command, select the 1400 dimension: one of the dimension's extension points is at Z height minus 109.7
The 4300 dimension has all of it's Z height settings at zero.
Looks like to snapped to an object far below the rest of your drawing for that one dimension (ermember, AutoCAD is a 3D program). You will need to recreate the odd singl 1400 dimension, set OSNAPZ to Zero may help if your snapped object must remain at that Z-minus location.
Since that's all your posted file contains I could not find how best to provide you with more details.
Active Contributor
riznasp
Message 7 of 9 (512 Views)
01-15-2014 12:45 AM in reply to: pendean
Thanks a lot my friend.
It was a great help. Is there any way to convert the existing dimension to a proper one or we'll have to do new dimensioning again?
Thanks & Regards
Riznas
*Expert Elite*
pendean
Message 8 of 9 (472 Views)
01-18-2014 02:59 AM in reply to: riznasp
Redraw from scratch was my observation in your file.
Active Contributor
riznasp
Message 9 of 9 (451 Views)
01-19-2014 12:43 AM in reply to: pendean
Thats fine. Thanks a lot for your help.
Riznas
You are not logged in.
Announcements
Manufacturing CAD & IT Manager Resource
Additional information for installing, licensing & deploying Inventor, the Product Design Suites and Factory Design Suites.
Need installation help?
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
