Dear All,
I have a problem with the dimension's arrow heads "architectural tick". It normally shows as filled but in the drawings it shows without fill (something like a wireframe). I have checked commands like fill, fillmode and display in the option. Could you please tell me what could be the reason.
Riznas
Solved by pendean. Go to Solution.
Thanks for your reply,
Shademode, ucs,... are all fine. When i copy the same dimensions to other files it show the same problem. Any other fix?
Riznas
Thanks a lot my friend.
It was a great help. Is there any way to convert the existing dimension to a proper one or we'll have to do new dimensioning again?
Thanks & Regards
Riznas
