Running command:
c:\progra~1\...\acad.exe
from a batch file causes Acad to crash with "exception in acmgd.dll arx command"
(win xp pro)
The same command run from a DOS command window works OK
The same command run for Acad2008 or 2004 runs OK too.
Anyone seen this?
Any help will be much appreciated.
alex
Pendean,
I did search and found all these posts. I even followed the instructions about NET .config files permissions etc.
But as I wrote, there is nothing wrong with my old software (2 years old Autocad to be exact).
It runs OK when started from the desktop or from a DOS box.
It's only when I try to start it from a batch file thet this happens.
Than you,
alex
Sure. Here it is, essentially a single line:
C:\Progra~1\Autodesk\AUTOCA~1\Acad.EXE
This is the only form which runs at all, albeit with the above errors.
But never mind that. I gave up on the batch file and wrote a little program in C# to do the job.
The question of the reasons for the problems above remains open.
alex
This format (DOS short paths) is the only format it would run at all (for paths containing spaces in the name).
All other ways (enclosing the full path in quotation marks, or enclosing only the names containing spaces, would not run at all from the batch file (as opposed to the command line).
Never mind, with DOS finally phased out, it remains an academic issue, albeit an intriguing one.
