Autodesk Technology Managers Forum
Share your knowledge, ask questions, and engage with fellow CAD/BIM Managers.
Message 1 of 9
435 Views, 8 Replies
Drawing Manager ??
We are currently looking for a program or software that will automatically
update a drawing's revision. Then move the older drawing to an archive
directory, or change the revision letter in the drawing name. Any
suggestions would be greatly appreciated.
John Laidler
Cad Manager
Duckworth & Associates, Inc.
(734) 455-7500
8 REPLIES 8
Message 2 of 9
Only as part of a large document management app.
Stuart Nathan @
http://www.dwgoffice.com
Message 3 of 9
It sounds simple enough. If your using R2000 or R2000i I may be able to
help you out. Do you want a command to perform this each time they open a
drawing or just when they run the command. Also, are all of the drawings
R2000 with the dwgprops tracking the revisions?
Rodney McManamy
President
MACSolids
Maximizing AutoCAD Solids
rmcmanamy@macsolids.com
"John Laidler" wrote in message
news:4EFB32A9DC86A5DC4CB7DDA9CD170C9E@in.WebX.maYIadrTaRb...
> John Laidler
> Cad Manager
> (734) 455-7500
Message 4 of 9
We're using A2Ki, but saving as R14.
The command shouldn't perform each time the drawing is opened, rather it
should perform when prompted.
"Rodney McManamy" wrote in message
news:53D0DAC15352A720CA1A71A725EE7B14@in.WebX.maYIadrTaRb...
> Rodney McManamy
> President
> MACSolids
automatically
> > John Laidler
> > Cad Manager
> > (734) 455-7500
Message 5 of 9
I don't think that R14 supported the dwgprops so I'm guessing that you would
be appending the revised drawing name.
Drawing-A.dwg -> Drawing-B.dwg
This is quick and dirty, no error checking involved bu will look for a
drawing revision at the end of the filename -A. If no revision is found
then it will create the -A revision. It will also attempt to create an
Old_Drawings subdirectory and move the old file over. It also saveas the
new drawing as the R14 dwg type for you. Help it helps but I haven't had my
morning coffee yet so I don't give any warranties. But it worked on my
NT4.0 and AutoCAD 2000i.
(defun c:revision (/ mac_acadapp mac_acaddoc
mac_acaddoc_name mac_acaddoc_basename mac_acaddoc_path
mac_acaddoc_fullname mac_oldrevision mac_acaddoc_basename
mac_newrevision mac_acaddoc_newname mac_acaddoc_newpath
mac_acaddoc_newfullname
(vl-load-com)
(setq mac_acadapp (vlax-get-acad-object)
mac_acaddoc (vlax-get-property mac_acadapp 'activedocument)
mac_acaddoc_name (vlax-get-property mac_acaddoc 'name)
mac_acaddoc_basename (vl-filename-base mac_acaddoc_name)
mac_acaddoc_path (vlax-get-property mac_acaddoc 'path)
mac_acaddoc_fullname (vlax-get-property mac_acaddoc 'fullname)
;; Determine if a drawing revision already exists as a letter
(if (wcmatch mac_acaddoc_basename "*-@")
(setq mac_oldrevision (strcase (substr mac_acaddoc_basename (strlen
mac_acaddoc_basename)))
mac_acaddoc_basename (substr mac_acaddoc_basename 1 (- (strlen
mac_acaddoc_basename) 2))
mac_newrevision (chr (+ (ascii mac_oldrevision) 1))
(setq mac_newrevision "A")
(setq mac_acaddoc_newname (strcat mac_acaddoc_path "\\"
"-" mac_newrevision ".dwg"
(vlax-invoke-method mac_acaddoc 'saveas mac_acaddoc_newname acr14_dwg)
;; Verify that the drawing was actually saved
(if (= (strcase (vl-filename-base mac_acaddoc_newname))
(strcase (vl-filename-base (vlax-get-property mac_acaddoc 'name)))
(progn
(alert (strcat "Drawing was saved as a new revision:\n"
;; Move the old drawing to an Old_Drawings Directory
(setq mac_acaddoc_newpath (strcat mac_acaddoc_path
"\\Old_Drawings")
mac_acaddoc_newfullname (strcat mac_acaddoc_newpath "\\"
mac_acaddoc_name)
;; Verify that the directory exists or create it
(if (= (vl-directory-files mac_acaddoc_newpath nil) nil)
(vl-mkdir mac_acaddoc_newpath)
(if (vl-directory-files mac_acaddoc_newpath nil)
;; Check if a drawing already exists in the Old_Drawings Directory
(if (findfile mac_acaddoc_newfullname)
(alert
(strcat "An existing file with the same name was\nfound in the
following directory:\n"
mac_acaddoc_newpath
"\nThe old drawing cannot be moved over to this directory."
;; No existing drawing was found so try to copy the old drawing over
(if (vl-file-copy mac_acaddoc_fullname mac_acaddoc_newfullname)
(if (vl-file-delete mac_acaddoc_fullname)
(alert
(strcat "The old drawing was moved over to this directory:\n"
(alert (strcat "The old drawing was copied over to this directory:\n"
mac_acaddoc_newpath
"\nBut it could not be deleted from the original directory."
(alert (strcat "The old drawing could not be copied to the following
directory:\n"
mac_acaddoc_newpath
(alert (strcat "The following directory could not be created:"
mac_acaddoc_newpath
(alert "An error occurred and the drawing was\nnot saved as a new
revision")
(princ)
Rodney McManamy
President
MACSolids
news:DB752E1A197C4A46CA3FC6695ED7129A@in.WebX.maYIadrTaRb...
a
drawings
> > Rodney McManamy
> > President
> > MACSolids
> automatically
archive
> > > John Laidler
> > > Cad Manager
> > > (734) 455-7500
Message 6 of 9
Thank you, it works perfectly.
news:82EEED6578AE334073E886A60CE531DC@in.WebX.maYIadrTaRb...
would
my
> (vl-load-com)
(strlen
> (progn
> "\\Old_Drawings")
> mac_acaddoc_name)
> (alert
> mac_acaddoc_newpath
> (alert
directory:\n"
> mac_acaddoc_newpath
> directory:\n"
> mac_acaddoc_newpath
> mac_acaddoc_newpath
> revision")
> (princ)
> Rodney McManamy
> President
> MACSolids
to
open
> a
> drawings
> > > Rodney McManamy
> > > President
> > > MACSolids
> > automatically
> archive
> > > > John Laidler
> > > > Cad Manager
> > > > (734) 455-7500
Message 7 of 9
one problem I just found though...
why won't it move the original file to Old_ Drawings.
It seems to always want 2 versions of the same drawing.
would
my
> (vl-load-com)
(strlen
> (progn
> "\\Old_Drawings")
> mac_acaddoc_name)
> (alert
> mac_acaddoc_newpath
> (alert
directory:\n"
> mac_acaddoc_newpath
> directory:\n"
> mac_acaddoc_newpath
> mac_acaddoc_newpath
> revision")
> (princ)
> Rodney McManamy
> President
> MACSolids
to
open
> a
> drawings
> > > Rodney McManamy
> > > President
> > > MACSolids
> > automatically
> archive
> > > > John Laidler
> > > > Cad Manager
> > > > (734) 455-7500
Message 8 of 9
Sorry, I forgot to release the drawing in the first example. this one
should work better.
(vl-load-com)
(progn
;; Release the old drawing
(vlax-release-object mac_acaddoc)
(vlax-release-object mac_acadapp)
"\\Old_Drawings")
mac_acaddoc_name)
(alert
mac_acaddoc_newpath
(alert
mac_acaddoc_newpath
directory:\n"
mac_acaddoc_newpath
mac_acaddoc_newpath
revision")
(princ)
Rodney McManamy
President
MACSolids
would
my
> (vl-load-com)
(strlen
> (progn
> "\\Old_Drawings")
> mac_acaddoc_name)
> (alert
> mac_acaddoc_newpath
> (alert
directory:\n"
> mac_acaddoc_newpath
> directory:\n"
> mac_acaddoc_newpath
> mac_acaddoc_newpath
> revision")
> (princ)
> Rodney McManamy
> President
> MACSolids
to
open
> a
> drawings
> > > Rodney McManamy
> > > President
> > > MACSolids
> > automatically
> archive
> > > > John Laidler
> > > > Cad Manager
> > > > (734) 455-7500
Message 9 of 9
Let's try this one more time. For some reason AutoCAD will not allow the
drawing to be deleted unless we use the saveas method twice on the new
drawing name? No idea why but it appears to work now.
(vl-load-com)
mac_acaddoc_backupfullname (strcat mac_acaddoc_path "\\"
mac_acaddoc_basename ".bak")
(progn
"\\Old_Drawings")
mac_acaddoc_name)
(alert
mac_acaddoc_newpath
(if (and (vl-file-delete mac_acaddoc_fullname)
(or (= (findfile mac_acaddoc_backupfullname) nil)
(vl-file-delete mac_acaddoc_backupfullname)
(alert
mac_acaddoc_newpath
directory:\n"
mac_acaddoc_newpath
mac_acaddoc_newpath
revision")
(princ)
Rodney McManamy
President
MACSolids
would
my
> (vl-load-com)
(strlen
> (progn
> "\\Old_Drawings")
> mac_acaddoc_name)
> (alert
> mac_acaddoc_newpath
> (alert
directory:\n"
> mac_acaddoc_newpath
> directory:\n"
> mac_acaddoc_newpath
> mac_acaddoc_newpath
> revision")
> (princ)
> Rodney McManamy
> President
> MACSolids
to
open
> a
> drawings
> > > Rodney McManamy
> > > President
> > > MACSolids
> > automatically
> archive
> > > > John Laidler
> > > > Cad Manager
> > > > (734) 455-7500
Administrator Productivity
