Used to, have not in many years.
The downsides to PLT files were that they are device specific, and you often had
to install a low-level, dummy HPGL/2 plotter to get a compatible PLT for the
recipient to use. But it would not support some of the more advanced features
like gradients or wipeouts.
The other huge problem is that they are huge.
We started using DWFs exclusively. Zero problems in plotting, a single DWF can
contain the entire sheet set, we can view and mark them up, and they are super
small.
Matt
matt@stachoni.com
On Fri, 12 Mar 2010 09:50:49 -0800, Jason Piercey wrote:
>I was asked by a client the other day to provide a PLT file(s).
>I haven't been asked for one of those in years. PDF wasn't
>acceptable since "they" do not have a "converter" for PDF
>and in-house plotting. Opening the PDF and printing it was
>not a solution from what I was told.
>Curious how many of you still use/produce PLT files.
>Guess I'll have to add PLT output to my automated system
>so I don't have to do each sheet one at at time.
