I am not sure what you mean, but if I have guessed right, you can use the
portable license so that you can have 3 licenses for use on the 6 pcs, but
only three of them at a time could be used. It is similar to checking a
book out of a public library. In this case you are checking the software
out of the network for use on machine A, and when it is done being used, it
is checked back in, and then machine E can check it out and use it. I think
there is a maximum of 6 months that it can be checked out, and I am not sure
if it would be a minimum of 24 hours or if there is no minimum time. This
would also work similarly if someone wanted to check it out for use on their
home PC or their home laptop.
The other 7 users would just sit all day, every day, at the same computers,
and use the 7 licenses. They also can utilize the portable license, but
would not usuall do so.
Someone else more familiar with this can go further in depth, but this is a
good subject for you to take up with your reseller.
Jack Talsky
