CAD Managers
New Member
Message 1 of 4 (375 Views)
Converting from Microstation to AutoCAD
375 Views, 3 Replies
05-13-2013 03:34 AM
Hiii,
I need to convert Microstation (.dgn) files to AutoCAD (.dwg) files. But after conversion the BOM ballons got changed in to boxes when opening in AutoCAD.
Please someone help me in this case as soon as possible,
Because i need to convert 11.000 files.  :smileysad:
*Expert Elite*
pendean
Message 2 of 4 (364 Views)
Re: Converting from Microstation to AutoCAD
05-13-2013 10:58 AM in reply to: Madan54
Microstation does the best job of conversion to DWG.
AutoCAD does not. If you have Eleven Thousand Files to convert you might consider purchasing a dedicated converter that will do all of those files unattended. Remeber to try before you buy.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
New Member
Message 3 of 4 (360 Views)
05-13-2013 11:21 AM in reply to: pendean
Ya .... Actually i am using "Batch Converter" in Microstation V8 XM Edition for converting the files.
Is there any other options to get this done.???
If u provide a solution for this, I will be very thankful for you ....  :smileyhappy:
Thanks in Advance.
*Expert Elite*
JGerth
Message 4 of 4 (334 Views)
05-14-2013 07:06 AM in reply to: Madan54
Out sourcing may be your best option for that volume, unless you have a lot of time in your budget and want to stay busy doing non-fun work.. Maybe hire an intern for the grunt work?
DWG /= DGN, and there will always be 'gotchas' that need a human being to validate and fix.
You are not logged in.
Announcements
Manufacturing CAD & IT Manager Resource
Additional information for installing, licensing & deploying Inventor, the Product Design Suites and Factory Design Suites.
Need installation help?
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
