Does anybody know is it possible to run various type of Autodesk products through Citrix Environment using a single license file for all products?
Any help would be appreciated.
Solved by DarrenP. Go to Solution.
Most 2013 versions of AutoCAD started with Citrix compliance, are these the versions you have, or lower? Be detailed.
only certain products are allowed to be used on citrix
and the licenses are per product
DarrenP
Thank you. In more details I'm interested in simultaneous working of Autocad 2013 and Revit® MEP 2013. All through Citrix Environment from one license file. Is this approach available now?
no
they are separate licenses
you have to buy both
talk to your reseller for pricing info
DarrenP
Dear DarrenP,
Assume I've already sold licenses of Autocad 2013 and Revit® MEP 2013.
Usually we ask Autodesk technicians to combine all licenses we have into one license file in order to use single machine to share licenses.
Is that approach available on Citrix or I have to use one Citrix machine for Autocad 2013 and another one for Autocad 2013?
now i know what you mean
you should be able to combine them in 1 license file just like a normal license file
DarrenP
