Autodesk Technology Managers Forum
Share your knowledge, ask questions, and engage with fellow CAD/BIM Managers.
Change Licpath.lic via vbscript
9 REPLIES 9
Message 1 of 10
1294 Views, 9 Replies
I have about a dozen autodesk products where I need to change the Licpath.lic.
According to Autodesk ADSKFLEX_LICENSE_FILE will not work with a redundant server setup so I need to replace the licpath.lic on every product.
Does anyone have a vbs script that they could share that copies over a new Licpath.lic file?
I would be using this as a machine script at bootup, not a login script.
9 REPLIES 9
Message 2 of 10
TravisNave
I recommend never using the redundant model because it does not work as intended and the only redundancy is the amount of work required to implement and keep it running.  Now that I am off my soap box, you can find a suitable solution here:
http://forums.autodesk.com/t5/Installation-Licensing/problem-changing-licencing-servers/td-p/2668660
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 3 of 10
in reply to: TravisNave
With a mixture of windows 7 and xp I want to avoid the registry. Things are setup with licpath now and I just need code to replace those files
Message 4 of 10
TravisNave
Since the file structure will be the same, you could just run a simple DOS batch file to do a copy overwrite from a shared location with the modified LICPATH.LIC to the Autodesk application root folder.
Autodesk Forums:
Message 5 of 10
If dos would work I would not be posting Windows 7 with the UAC will not allow writing to the c:\program files locations
Message 6 of 10
TravisNave
You need to disable UAC.  It serves no purpose but to make your life miserable.  Definitely doesn't need to be enabled in an enterprise setting.  You have group policies for that.  I never understood why people insist on handicapping themselves and then try to explain ways around the very obstacles they set for themselves.  If you're looking for a method to circumvent UAC, then UAC really isn't serving its purpose.  If you can circumvent it, anyone can.  Just turn it off.
Autodesk Forums:
Message 7 of 10
We are arguing about a non point here I just need vbs code I figured other cad managers had the code already I will ask in a Microsoft group instead Btw the it department sets UAC, not the cad managers
Message 8 of 10
TravisNave
I wish you luck.  I can attest that as part of IT, I would never set UAC on my users.  Perhaps your IT can make an exception for your engineers, or at the very least, in the short term while you enlist your necessary changes.
Autodesk Forums:
Message 9 of 10
We are probably going to turn it off but again non issue
I want vbs, its more transparent to the users.
Message 10 of 10
TravisNave
I can respect that.  The IT guy in me says to just use the login script... but you probably really don't have access to that!  Smiley Very Happy
Autodesk Forums:
Administrator Productivity
