CAD Managers
New Member
simonbanyard
Message 1 of 3 (951 Views)
CAD Manager Control Utility not running
951 Views, 2 Replies
02-27-2012 09:29 AM
Hi all,
I've searched the forums looking for a solution for my issue without any luck. I have the CAD Manager Control Utility installed from the Building Design Suite Premier (ACAD, 3ds max and Revit installed) and when I launch it the software returns the following;
"No Autodesk-based product key in registry. Please use the CAD Manager Control Utility on a computer containing the Autodesk-based product you wish to modify."
I found this link http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13158781&linkID=9240858 but it seems to be specifically to fix a problem with Civil 2010.
Any ideas for a solution or help would be much appreciated.
(OS: Win 7 x64)
*Expert Elite*
TravisNave
Message 2 of 3 (930 Views)
Re: CAD Manager Control Utility not running
02-28-2012 10:25 AM in reply to: simonbanyard
Have you actually tried the instructions in that link?  It looks as though it's just xml pointers. Even if it doesn't work, you should be able to modify them to fit your current needs, I would think.
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
Distinguished Contributor
Brausmith
Message 3 of 3 (873 Views)
03-22-2012 07:27 PM in reply to: simonbanyard
I just installed the utility and am getting the exact same message. This is despite having the Building Design Suite Ultimate installed with a valid serial.
I followed the link in the original post and checked the registry for the presence of the serial numbers and they are there.
Chad
You are not logged in.
Announcements
Manufacturing CAD & IT Manager Resource
Additional information for installing, licensing & deploying Inventor, the Product Design Suites and Factory Design Suites.
Need installation help?
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
