CAD Managers
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
CAD Manager Control Utility not running
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi all,
I've searched the forums looking for a solution for my issue without any luck. I have the CAD Manager Control Utility installed from the Building Design Suite Premier (ACAD, 3ds max and Revit installed) and when I launch it the software returns the following;
"No Autodesk-based product key in registry. Please use the CAD Manager Control Utility on a computer containing the Autodesk-based product you wish to modify."
I found this link http://usa.autodesk.com/adsk/servlet/ps/dl/item?si
Any ideas for a solution or help would be much appreciated.
(OS: Win 7 x64)
Re: CAD Manager Control Utility not running
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Have you actually tried the instructions in that link? It looks as though it's just xml pointers. Even if it doesn't work, you should be able to modify them to fit your current needs, I would think.
My Expert Contributions to the Discussion Groups: FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!Re: CAD Manager Control Utility not running
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I just installed the utility and am getting the exact same message. This is despite having the Building Design Suite Ultimate installed with a valid serial.
I followed the link in the original post and checked the registry for the presence of the serial numbers and they are there.
Chad
