• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    CAD Managers
    Distinguished Contributor
    CAD Manager Channel RSS Feed
    318 Views, 21 Replies
    09-26-2008 08:47 AM
    Has anyone been able to get the CAD Manager Channel RSS feed to use a feed from Windows Sharepoint Services 3.0? That is what we use for our Intranet and it would be nice to use it for my CAD Manager Feed.
    Please use plain text.
    *clintonG
    Re: CAD Manager Channel RSS Feed
    10-02-2008 08:54 AM in reply to: pcchenard
    Resolved yet?
    wrote in message
    news:6039630@discussion.autodesk.com...
    10-02-2008 09:12 AM in reply to: pcchenard
    I have not looked into it any further. When entering the link when creating the deployment it says that it is an invalid link. I guess it wants a link that ends with .xml but SharePoint doesn't do it that way. It is just a link like this:
    https://webserver/CAD/_layouts/listfeed.aspx?List=%7B610181F2%2DD0D1%2D4E2A%2D9013%2D22B700E68FC5%7D
    Maybe it can't handle the SSL?
    *clintonG
    10-04-2008 07:12 AM in reply to: pcchenard
    While this vendor is subversive and has obstructed customer's use of the
    Internet Protocols forcing them to operate at a loss in an attempt to compel
    the customer to use their own proprietary services having observed your URL
    indicates the problem is on your end: GIGO (Garbage In -- Garbage Out) so
    no, on the basis of what you provide as the URL its not the https scheme or
    the file extensions its the rest of the URL which cannot be resolved as it
    is not well-formed nor valid and as such a remote request for a resource
    cannot be resolved.
    Do you want to walk through this together and devise a work-around?
    "pcchenard" wrote in message news:6043591@discussion.autodesk.com...
    like this:
    *clintonG
    10-04-2008 10:25 AM in reply to: pcchenard
    Actually part of my reply should have said --yes-- agreeing with your
    comment about the missing file extension but the rest of the URL is not
    well-formed, invalid and therefore cannot be resolved..
    "clintonG" wrote in message
    news:6045087@discussion.autodesk.com...
    cannot be resolved.
    like this:
    10-06-2008 05:40 AM in reply to: pcchenard
    I do agree that the URL is not well formed. But it is a valid URL none the less and I can subscribe to the feed with IE7 just fine and the URL also works fine with Firefox. So there is no reason why it shouldn't work with any other program that will read a RSS feed.
    I'm not interested in putting any effort into a work around at this time. But thanks for the offer to help.
    *clintonG
    10-06-2008 09:10 AM in reply to: pcchenard
    Seeing it for what it was (not) there is no way DNS can resolve a malformed
    and invalid URL requested from the web itself so no, it is not a valid URL
    as there is no domain name in the URL for DNS to resolve. I must assume some
    software you are using is rewriting the URL which is very common and why you
    can load some "thing" noting what you are loading is the result of a file
    returned --after-- some software transforms and resolves the URL.
    My guess is you're likely using some goofy "free" 3rd party web part
    installed in SharePoint but who knows eh? Maybe Microsoft really has sold
    millions of licenses of their SharePoint software that does not support the
    currently most widely used Internet Protocol.
    Testing the Web feed itself is really not that much work and is a skill
    every CAD Manager --should-- have acquired. Noting Firefox is buggy and does
    not render raw XML correctly (unless you disable feed reading and then use
    View Source) so for this task I would recommend using IE since we have to
    disable feed reading anyway...
    // IE7
    Tools > Internet Options > Content (tab) > Settings (button)
    Uncheck: Turn on feed reading view
    Load the feed and save the raw XML file putting it someplace that can be
    requested over the web. In this context the file extension can be .rss or
    .xml. Submit the feed to the W3C Validator [1] to ensure the XML in your
    feed is well-formed and valid --or-- we can copy and paste the raw XML and
    submit that to the validator.
    [1] http://validator.w3.org/feed/
    "pcchenard" wrote in message news:6045413@discussion.autodesk.com...
    any other program that will read a RSS feed. I'm not interested in putting
    help.
    10-06-2008 09:22 AM in reply to: pcchenard
    Sorry. I assumed you would know that I had edited the web server name. I guess I should have noted that I replaced the actual web server name with "webserver" because it is a public name and I did not want to post it here. It is a valid DNS name. That is not the problem. I guess a better "edited" example of the URL would be:
    https://webserver.mydomain.com/CAD/_layouts/listfeed.aspx?List=%7B610181F2%2DD0D1%2D4E2A%2D9013%2D22B700E68FC5%7D
    *clintonG
    10-06-2008 04:36 PM in reply to: pcchenard
    Okay, from that we can discuss the rest of the URL. I see it contains an
    ASP.NET file and a QueryString named List. The application the URL is being
    submitted to would need to know how to compile listfeed.aspx, i.e. some
    Windows platform with the .NET Framework installed and finally the CAD
    Manager.
    When listfeed.aspx is compiled some "code behind" in listfeed.aspx.cs or
    listfeed.aspx.vb (as the case may be) would typically use an instance of a
    Request object to read the QueryString named List and deserialize its
    encoded value which is that long hunk of alphanumeric characters the CAD
    Manager doesn't know what to do with. Does that make sense?
    "pcchenard" wrote in message news:6045617@discussion.autodesk.com...
    10-07-2008 05:22 AM in reply to: pcchenard
    Yes it makes complete sense. I'm just amazed that Autodesk does not write the CAD Manager so that it can utilize the list feed from SharePoint. It is so widely used now that it should be supported.
