• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    CAD Managers
    Member
    Autodesk Iventory Advisor - Installation type info
    312 Views, 5 Replies
    06-04-2012 11:45 AM
    Hi, I m using Autodesk Inventory Advisor tool to get the numbers of license already used on my LAN, and that's work great, but I want to get the installation type too, and this field only shows some numbers, 0,1 and 3, I'm looking  for some information about this, what does it means each number? Please if someone knows something about it, reply me, or maybe some post or manual to get more info about the tool.
    Thanks and Regards
    Please use plain text.
    *Expert Elite*
    TravisNave
    Re: Autodesk Iventory Advisor - Installation type info
    06-07-2012 09:50 AM in reply to: egonzalo
    I would suspect they refer to stand-alone, network, or multi-seat stand-alone.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Member
    06-07-2012 09:59 AM in reply to: egonzalo
    Hi, and thanks for your reply Travis. I found this info from a older post, but i'm not sure if it's apply for this tool also:
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17847202&linkID=9242018
    It's say the following:
    1 – Network
    2 – Standalone
    3 – Multiseat Standalone
    But i have as result differents numbers: 0,1 and 3
    *Expert Elite*
    TravisNave
    06-07-2012 10:13 AM in reply to: egonzalo
    It wouldn't surprise me if it was basically the same thing.
    Travis Nave
    Member
    06-07-2012 10:19 AM in reply to: egonzalo
    Right, I just wish  to validate these values, I consider is a important thing which should be include on the manual, cause the goal for the tool is to get autodesk licenses including installations type
    *Expert Elite*
    TravisNave
    06-07-2012 10:33 AM in reply to: egonzalo
    Right. I mean, the tool clearly states that it lists license type. And in all reality there can only be 4 different types. Stand-alone, network, multi-seat stand-alone, and trial. I am sure those numbers translate to that. I am surprised there is no key in the guide or help system.
    Travis Nave
