Autodesk Technology Managers Forum
Share your knowledge, ask questions, and engage with fellow CAD/BIM Managers.
AutoCAD file converted to Microstation, why can't I get rid of the "0" layer?
1 REPLY 1
chadmart
1204 Views, 1 Reply
I have an AutoCAD file that I converted to Microstation. In that file are the two layers that AutoCAD can't live without, "Defpoints" and "0". When I convert I use the standards checker to move anything that might have been on those levels onto other levels. At this point I can compress the drawing. The "Defpoints" level goes away by the "0" level remains. In the level manager it doesn't have a dot under the "used" column. When I try to manually delete it, it states "Cannot delete Default Level". I know that Microstation doesn't require the "0" level like AutoCAD does because I have other drawings that do not have it that were created in Microstation. Any clues how to get rid of it? The client doesn't like these non-standard levels in the drawings.
P.S. I know that this is an AutoCAD forum and this is really a Microstation question, but I think it is relevent enough to still be asked here. Plus, I don't know any MS boards that are as good as this ACAD board. Thanks for any help!
1 REPLY 1
jggerth1
in reply to: chadmart
At a guess, there are block definitions in the drawing that were created on the 0 layer.  so although no objects are on the layer, it's part of the block/cell definition.  damifino how to go about resolving that on the uStn side.
Administrator Productivity
