I have an AutoCAD file that I converted to Microstation. In that file are the two layers that AutoCAD can't live without, "Defpoints" and "0". When I convert I use the standards checker to move anything that might have been on those levels onto other levels. At this point I can compress the drawing. The "Defpoints" level goes away by the "0" level remains. In the level manager it doesn't have a dot under the "used" column. When I try to manually delete it, it states "Cannot delete Default Level". I know that Microstation doesn't require the "0" level like AutoCAD does because I have other drawings that do not have it that were created in Microstation. Any clues how to get rid of it? The client doesn't like these non-standard levels in the drawings.
P.S. I know that this is an AutoCAD forum and this is really a Microstation question, but I think it is relevent enough to still be asked here. Plus, I don't know any MS boards that are as good as this ACAD board. Thanks for any help!
