Autodesk Technology Managers Forum
Share your knowledge, ask questions, and engage with fellow CAD/BIM Managers.
Authorization Code HTML file path for 2012 products
2 REPLIES 2
tahdesign1
919 Views, 2 Replies
I am trying developing a new method for tracking my installs and would like to match things up to the authorization codes on each of the pc's.
I know there used to be an HTML file on the install drive somewhere that housed this information but I can not find it on my Win7 AutoCAD/Inventor 2012 install boxes.
Anybody know where this file is located now or at least the name of it?
I know I can go to Help>About>Product Information to see some of this information but what I am looking for is the file that contains the Authorization code that I can match to the emails I get when a product is registered.
2 REPLIES 2
tahdesign1
in reply to: tahdesign1
Basically I am looking for the file that is feeding the attached dialog box. I believe it is also housing the request and authorization codes.
TravisNave
That information is encrypted, so I doubt that you will be able to retrieve it.
Autodesk Forums:
Administrator Productivity
