• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    CAD Managers
    Active Member
    Accepted Solution
    Attaching Xref
    329 Views, 3 Replies
    02-23-2012 04:09 PM
    When we attach an exref we have to set the layer first, (XREF) and then attach the file we want.
    I'm looking for a way to simplfy the process by combining the two tasks.
    For one, it seems I'm not on the "right" layer when I attach an xref often.
    I was thinking of a custom icon perhaps on a toolbar that when launched would first set the layer to XREF and then proceed to attaching the XREF
    Appreciate you help.
    Mark
    Please use plain text.
    skintsubby
    Re: Attaching Xref
    02-23-2012 11:26 PM in reply to: ldcadman
    Try adding the follow macro to an icon
    ^C^C_-layer;m;xref;c;white;xref;^C^C_-xref;a;
    It will create layer "Xref" and give it the colour white, then open your xref manager.
    Mark
    Active Member
    Re: Attaching Xref
    02-24-2012 05:26 AM in reply to: ldcadman
    Thank you for your reply.
    I'm wondering what will happen if the file I attempt to attach an Xref with that command line if it already has a layer xref?
    Mark
    *Expert Elite*
    pendean
    Re: Attaching Xref
    02-24-2012 07:52 AM in reply to: ldcadman
    The macro above uses -LAYER command's MAKE sub-option: look it up in HELP, it works without worries about if the layer is already in the file or not.
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
