In article <4842610@discussion.autodesk.com>, ABoyd <> says...
> I posted this in the adt2006 forum with no results, hopefully i'll have more luck here:
> I'm currently running Argos 5.0 & adt2005 in an office environment.
> In preparation for a switch to adt2006 I've installed adt2006 on my computer and now I'm prompted with an error every time i print from any application (see attached image) and have to cancel out of a few screens before the dialog boxes go away.
> my problem is similar to the post in the adt2005 forums
> Posted by: consistence Date: J
> un/09/04 - 10:10 (EDT)
> but no solution was posted to the forums.
> any help would be greatly appreciated.
> [image/jpeg]
ABoyd,
I posted a response to the ADT2006 group as well.
There was an issue with the MSI installer for AutoCAD and derived
products that caused the installer to launch "spontaneously" when used
with Argos 5. Specifically, the issue relates the the "vizrender"
feature in AutoCAD. The issue was resolved by Autodesk in AutoCAD 2005
SP1. I presume that a corresponding ADT2005 SP1 would also resolve the
problem.
Although the problem was ultimately with the AutoCAD installer, we have
not seen this problem at all with Argos 6 (6.1 is the latest version).
We are unaware of any issues with the 2006 family of products, but if
you're seeing it with '06, please contact our support at
support@sepialine.com, or (800) 404-9558, and we'll take a look at it.
Hope this helps.
Ray Bradley
Sepialine
