• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    CAD Managers
    TravisNave
    Re: Anyone try Windows 8 Developer preview?
    03-05-2012 12:20 PM in reply to: kienduday
    What is your video card and driver?  Does AutoCAD fail to run after this error?
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Please use plain text.
    03-05-2012 04:36 PM in reply to: TravisNave
    My card is Radeon HD 6770 , Driver on web of ATi was update date new version . I was use on win 7 , not erro ...
    If click Ok erro , it dis to windows :smileysad:
    03-05-2012 04:59 PM in reply to: TravisNave
    Ah , I know reasons, this is driver graphic card of win 8 . I was reinstall driver on ATi's web, it work , but after update driver on win 8 , it erro :smileyhappy:
    TravisNave
    03-06-2012 11:33 AM in reply to: kienduday
    Excellent.  That's kinda what I figured was the problem.  I am not a fan of ATI drivers at all.
    ATI = Always Trashes Inventor.  :smileyvery-happy:
    Travis Nave
    03-06-2012 03:28 PM in reply to: TravisNave
    When will Autodesk 2013 be release ? :smileyhappy:
    TravisNave
    03-06-2012 03:48 PM in reply to: pendean
    You know we're not allowed to tell. ;-)
    Soon!
    Travis Nave
    03-07-2012 05:02 AM in reply to: TravisNave
    Just tell me a little bit ,ok ! he he :smileywink:)
    pendean
    03-08-2012 04:53 AM in reply to: kienduday
    After R2009 upgrade window/period dies (currently slated for March 15): historically that's been the case, not sure they plan on changing.
    This was tweeted yesterday, no mention of Win8 of course:
    Lynn_Allen #AutoCAD 2013 System Requirements http://t.co/D6Dmw6nu (http://inventortopix.blogspot.in/2012/03/autocad-2013-system-requirements.html)
    Dean Saadallah LT BLOG | RSS Feed | LT Tips | PINS
    03-09-2012 05:52 PM in reply to: TravisNave
    Waiting Waiting ... :smileyhappy:
    But why not support Win8 and Framework 4.5 :smileysad:
    New Member
    03-11-2012 05:30 PM in reply to: TravisNave
    With all due respect, your fix doesn't work.
    First, I should tell you that I have Windows 8 and Autocad 2012 with a downloaded zip file from Autodesk.
    Second, my error message is for the .net frameowork, which I assume is because 4.5 is part of the new operating system and it won't allow any installation of 4.0.  I tried installing 4. directly from Microsoft, but that wasn't allowed either.
    This is what I did:
    1. I deleted all the dot 4 references. That didn't work.
    2. I replaced your setup.ini file that you provided in the thread with the original, but that didn't work.
    3. After I realized that when the program is unzipping, it replaces the setup.ini file that I changed back to the original one, so I waited until it stopped unzipping to replace it.  That didn't work.
    Are there two setup.ini files?
     But I doubt that is the problem.  I am getting the setup.ini file in the main folder of the Archicad file.  It is right under the setup.exe file.
    4.  I  tried using every compatibility settings going back to XP.  That didn't work.
    Lastly, I have played with turning on and off the .net framework programs, but that doesn't worh either.
