CAD Managers
TravisNave
Message 11 of 68 (9,035 Views)
Re: Anyone try Windows 8 Developer preview?
03-02-2012 01:14 PM in reply to: kienduday
Open up your setup.ini file and do a search for DOTNET.  That will allow you to remove all the prerequisite checks for all the .NET versions.  Remove every single one.  Then at the bottom section where the DOTNET section begins, delete everything in between the beginning and ending comments.  Save the file.  Run setup as W7 compatibility mode as Administrator.
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
kienduday
Message 12 of 68 (9,033 Views)
03-02-2012 01:30 PM in reply to: TravisNave
I was installed without Framework . Thank you so much .
I'm not sure it will erro but now it's work . Will file install be fix in future ? :cathappy:
kienduday
Message 13 of 68 (9,030 Views)
03-02-2012 01:39 PM in reply to: TravisNave
oh no , "load library failed error 126" , how do fix ? :catsad:
TravisNave
Message 14 of 68 (9,027 Views)
03-02-2012 01:41 PM in reply to: kienduday
I didn't get that error.  Are you running the program now in Windows 7 compatibility mode as Administrator?  Try that.
It's unlikely for there to be a compatibility fix for this release in the future.  Perhaps AutoCAD 2013 if we're lucky.
Valued Contributor
mgalicki
Message 15 of 68 (8,989 Views)
03-05-2012 08:34 AM in reply to: TravisNave
Travis, what portion of the file am I to erease? Just the GREEN in my screen shot? Thanks, Mark
Everything in existence was first an Idea
Autodesk Plant 3D Premium 2012
Autodesk MEP 2012
HP 3.2 Ghz CPU 16 ram
1TB 7200 rpm SATA 3Gb/s hard drive
2GB DDR3 NVIDIA GeForce GT 530
HP 2311x 23" LED Monitor
TravisNave
Message 16 of 68 (8,973 Views)
03-05-2012 10:17 AM in reply to: mgalicki
Correct.  Just F3 it all the way down and remove all the DOTNET references for all products.  You will also have to remove the program section for DOTNET at the end of the file too.
TravisNave
Message 17 of 68 (8,971 Views)
03-05-2012 10:19 AM in reply to: kienduday
Here is my modified setup.ini file for vanilla (x64) AutoCAD 2012.  You should be able to unzip it and use it on AutoCAD or use it as a reference to modify other Autodesk products.
kienduday
Message 18 of 68 (8,962 Views)
03-05-2012 10:56 AM in reply to: TravisNave
It was intalled but it don't work . "load library failed error 126" . Wait 2013 version ... :smileysad:
TravisNave
Message 19 of 68 (8,957 Views)
03-05-2012 11:41 AM in reply to: kienduday
After modifying the .ini file and overwriting the one that is copied to the hard drive, here is my process:
1.  Login as a local administrator
2.  UAC and antivirus (if installed) is disabled
3.  Right-click setup.exe and go to Properties
4.  Set Compatibility mode to Windows 7
5.  Check to run as Administrator and click OK
Run setup.exe and install as expected (not adding any service packs to the install.)  This went on without a hitch for me once it was completed.  I used vanilla AutoCAD 2012 from DVD media copied to the hard drive with the modified setup.ini that I provided.
Once installed, I set the file properties of acad.exe to Windows 7 compatibility mode as well.  It launched without error.  I am using a network licensed copy.  I did not test this with stand-alone.
Your Load Library Failed Error 126 error could be due to your graphics card, especially if using an AMD/ATI Radeon card.  I am using an nVidia card.  You might consider updating your driver if that is an option for you on W8.
kienduday
Message 20 of 68 (8,949 Views)
03-05-2012 12:02 PM in reply to: TravisNave
Sorry , I failed .I was do that you said but it not work
You are not logged in.
Manufacturing CAD & IT Manager Resource
Additional information for installing, licensing & deploying Inventor, the Product Design Suites and Factory Design Suites.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
