• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    CAD Managers
    *Expert Elite*
    TravisNave
    Re: Anyone try Windows 8 Developer preview?
    03-02-2012 01:14 PM in reply to: kienduday
    Open up your setup.ini file and do a search for DOTNET.  That will allow you to remove all the prerequisite checks for all the .NET versions.  Remove every single one.  Then at the bottom section where the DOTNET section begins, delete everything in between the beginning and ending comments.  Save the file.  Run setup as W7 compatibility mode as Administrator.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Please use plain text.
    03-02-2012 01:30 PM in reply to: TravisNave
    I was installed without Framework . Thank you so much .
    I'm not sure it will erro but now it's work . Will file install be fix in future ? :cathappy:
    03-02-2012 01:39 PM in reply to: TravisNave
    oh no , "load library failed error 126" , how do fix ? :catsad:
    *Expert Elite*
    TravisNave
    03-02-2012 01:41 PM in reply to: kienduday
    I didn't get that error.  Are you running the program now in Windows 7 compatibility mode as Administrator?  Try that.
    It's unlikely for there to be a compatibility fix for this release in the future.  Perhaps AutoCAD 2013 if we're lucky.
    Travis Nave
    Valued Contributor
    03-05-2012 08:34 AM in reply to: TravisNave
    Travis, what portion of the file am I to erease? Just the GREEN in my screen shot? Thanks, Mark
    Everything in existence was first an Idea
    Autodesk Plant 3D Premium 2012
    Autodesk MEP 2012
    HP 3.2 Mhz CPU 16 ram
    1TB 7200 rpm SATA 3Gb/s hard drive
    2GB DDR3 NVIDIA GeForce GT 530
    HP 2311x 23" LED Monitor
    *Expert Elite*
    TravisNave
    03-05-2012 10:17 AM in reply to: mgalicki
    Correct.  Just F3 it all the way down and remove all the DOTNET references for all products.  You will also have to remove the program section for DOTNET at the end of the file too.
    Travis Nave
    *Expert Elite*
    TravisNave
    03-05-2012 10:19 AM in reply to: kienduday
    Here is my modified setup.ini file for vanilla (x64) AutoCAD 2012.  You should be able to unzip it and use it on AutoCAD or use it as a reference to modify other Autodesk products.
    Travis Nave
    03-05-2012 10:56 AM in reply to: TravisNave
    It was intalled but it don't work . "load library failed error 126" . Wait 2013 version ... :smileysad:
    *Expert Elite*
    TravisNave
    03-05-2012 11:41 AM in reply to: kienduday
    After modifying the .ini file and overwriting the one that is copied to the hard drive, here is my process:
    1.  Login as a local administrator
    2.  UAC and antivirus (if installed) is disabled
    3.  Right-click setup.exe and go to Properties
    4.  Set Compatibility mode to Windows 7
    5.  Check to run as Administrator and click OK
    Run setup.exe and install as expected (not adding any service packs to the install.)  This went on without a hitch for me once it was completed.  I used vanilla AutoCAD 2012 from DVD media copied to the hard drive with the modified setup.ini that I provided.
    Once installed, I set the file properties of acad.exe to Windows 7 compatibility mode as well.  It launched without error.  I am using a network licensed copy.  I did not test this with stand-alone.
    Your Load Library Failed Error 126 error could be due to your graphics card, especially if using an AMD/ATI Radeon card.  I am using an nVidia card.  You might consider updating your driver if that is an option for you on W8.
    Travis Nave
    03-05-2012 12:02 PM in reply to: TravisNave
    Sorry , I failed .I was do that you said but it not work
