• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    CAD Managers
    *Expert Elite*
    pendean
    Anyone try Windows 8 Developer preview?
    12814 Views, 63 Replies
    02-28-2012 05:59 AM
    Or have plans to try the public Beta of Windows 8 to be released soon?
    I had greate success with the Win7 beta and wondering if Windows8 will be the same experience.
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    Please use plain text.
    *Expert Elite*
    DarrenP
    Re: Anyone try Windows 8 Developer preview?
    02-28-2012 08:19 AM in reply to: pendean
    i tried to install autocad 2012 on win 8 dev preview
    it won't get past the setup screen i can't even click on install products without it crashing
    *Expert Elite*
    TravisNave
    02-29-2012 02:35 PM in reply to: pendean
    Gentlemen,
    I decided to give it a try today.  At first I ran into a lot of the usual suspects.  But eventually, I was able to get AutoCAD 2012 up and running on the latest Windows 8 build 8250.
    I copied the contents of the AutoCAD disc to the HDD.  Then I modified the setup.ini file and removed all instances of DOTNET from the prerequisites.  Windows 8 already has .NET 4 preloaded into the OS, so the installer will fail if this step is not done.  Once I saved the setup.ini file, I changed the properties of setup.exe to run in Windows 7 Compatibility mode and to Run as Administrator.  The installer went on without a hitch.
    I launched the product (also Win7 compatibility) and was able to pull a network license from my license manager after my trusty IPv6 technique.
    Edit:  On a side note, I installed LMTOOLS 11.10 but the licensing for adskflex.exe did not work.  I went back down to adskflex.exe 11.7 and it fired off.  Seems that the latest 11.9 adskflex.exe has the same connectivity issues on Windows 8 as Server 2008 R2.  Stands to reason...
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    *Expert Elite*
    pendean
    03-01-2012 05:55 AM in reply to: TravisNave
    Thanks for the tips: I will download Win8 CP this evening, install it on my Slate and give it all a good try out.
    If anyone else is wondering about Win8, these help a lot:
    http://www.theverge.com/2012/2/29/2833006/how-to-install-windows-8-consumer-preview
    http://www.computerworld.com/s/article/9224785/Windows_8_What_you_need_to_get_started?taxonomyId=89
    *Expert Elite*
    DarrenP
    03-01-2012 06:10 AM in reply to: pendean
    the OS is pretty cool
    i only wish i had tablet to test this on
    *Expert Elite*
    pendean
    03-01-2012 06:40 AM in reply to: DarrenP
    I'm counting on Win8 being a big improvement on a tablet: my Samsung Slate is seriously handicapped by Win7 when it comes to touch-screen use in many areas, all it offers are work-arounds that are not smooth at all.
    *Expert Elite*
    TravisNave
    03-01-2012 10:55 AM in reply to: pendean
    Agreed.  I've only found a few minor complaints so far with this preview release.  The missing Start menu had me worried at first until I realized that I never use the Start menu now anyway.  Might be an adjustment for my users though.  Doesn't seem to be a way to enable it either like in previous beta releases.  The other thing I don't like is the missing setting for managing wifi connections.  They've even changed it enough that the export wifi to USB no longer works to import previous settings.  There's also some difference in how it is resolving DNS because I was having problems with the hosts file and making it recognize changes to the file.
    Clearly this OS was designed to be on a tablet or a device that at least has touch screen or pen input.  I see no reason to upgrade to Win8 over Win7 unless this functionality is important to you.  Also doesn't seem that the app store (currently free) has Angry Birds yet.  :smileyvery-happy:
    From an IT stand-point, there doesn't seem to be a lot of change on commands, MMC, the run box, and all the other shortcuts and tricks.  It's not ready for prime time yet.  But AutoCAD works on it.  Ha!
    Travis Nave
    *Expert Elite*
    DarrenP
    03-01-2012 10:59 AM in reply to: TravisNave
    microsoft also released server 8 consumer preview
    that seems to geared towards cloud enviroments
    *Expert Elite*
    TravisNave
    03-01-2012 11:01 AM in reply to: DarrenP
    I am not brave enough to put a beta server on my enterprise.  hahaha!  It might turn my infrastructure into clouds!  :smileyvery-happy:
    Travis Nave
    03-02-2012 01:07 PM in reply to: TravisNave
    Can you send me your file setup.ini of AutoCad 2012 ? I can't install AutoCad because framework .
