• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    CAD Managers
    *logardrums
    Any free lance Cad people out there?
    413 Views, 9 Replies
    11-20-2002 04:47 AM
    Does anyone do free lance cad work? If so, how much do you charge per hr?
    I'm just doing a litle research, because I may have to move to another
    state, and I will most likely be able to do my Company's cad work from my
    new home. I mainly do Civil design and land development , but I'm curious
    what free lance cad people get across the board. I'm considering 25-35 bucks
    an hour.
    Chris
    Please use plain text.
    *johnosn, dc
    Re: Any free lance Cad people out there?
    11-20-2002 05:01 AM in reply to: *logardrums
    not a free lance but I would not go below $30 I would try for $35 to $40
    Dave C. Johnson
    WWC Engineering
    Sheridan WY.
    Windows 2k
    Acad Map 5
    Survcadd XML
    remove OUT to reply
    *Turvill, Paul
    11-20-2002 05:03 AM in reply to: *logardrums
    It depends a whole lot in which *profession* you work. After all, CAD is a
    tool, not an end in itself. If you do drafting, your figure probably isn't
    far off the mark; however, if you do original design, engineering, etc., and
    can provide professionally certified (i.e., a PE or RA seal) work, then you
    could easily command 2-3 times that amount, depending on which region of the
    country/world you end up in.
    ___
    "logardrums" wrote in message
    news:F2ACD05E1A78F591887426E7F81D0737@in.WebX.maYIadrTaRb...
    > Hi,
    bucks
    > an hour.
    > Thanks,
    > Chris
    Distinguished Contributor
    11-20-2002 05:20 AM in reply to: *logardrums
    I do some free lance work (mostly design) and coaching of Autocad-scared architects, interior designers, and students. You do not say whether you are designing or putting others' work into dwg. Working for your old company, you might get less $ but a guarantee of more work. Charge more for new ones, check compettion in your specialties. Bob
    *Ted
    11-21-2002 12:18 AM in reply to: *logardrums
    Depends on if you have to buy your own equipment. The only way you should
    ask for as low as $30 per hour is if they supply you with a computer and
    AutoCAD. Make sure you get to keep the equipment and try for an allowance
    for upgrades. Other then that I would be charging about double what you
    made working for the company.
    | Hi,
    bucks
    | an hour.
    | Thanks,
    | Chris
    Valued Contributor
    Re:
    11-21-2002 01:13 AM in reply to: *logardrums
    This is piquing my interest in venturing into free-lancing on the side. What kind of equipment is typical in addition to PC and ACAD software? Also, what suggestions do you have to hunt down this type of work? Does this work usually require a business license in the municipality where you reside? I could use the money and utilize the experience I've gained in drafting and other specialties. Thanks in advance for any information you can give.
    Tom
    *Friedrich, Peter
    11-21-2002 01:41 AM in reply to: *logardrums
    Been there... done that!
    Consider---
    - are you a draftsman (cad or not, what's that worth?)
    - are you more than that-- customization? Specialist? Designer? Civil &
    land are worth a good premium*
    - What's the turnaround time - BE QUICK OR ELSE!*
    - What tools do you have to ensure speed - and what do they cost.
    - BE LEGAL - no pirate software should be employed by a freelancer unless
    he/she is inviting legal troubles.
    *- the premium noted here is ONLY if your deliveries can be prompt- and
    You'll need a fast machine for any medium to large project, anyway.... let
    your customer(s) know that'll cost - and Be Certain your deliveries
    demonstrate and justify the cost.
    - benefits (vacation - allow for some- although it may be on their schedule,
    now), insurance, some travel (don't be faceless), and other desirables may
    be factors in your price, too.
    My guess is $30 is a low starting point - but where are you/your
    customer(s), and what are the local rates?
    I doubt I could sell my services in Mississippi and make a profit with NJ
    living expenses, for instance.
    Good Luck!
    > Hi,
    bucks
    > an hour.
    > Thanks,
    > Chris
    *Ted
    Re:
    11-21-2002 07:06 AM in reply to: *logardrums
    I have only done minor freelance work.  If I
    were doing more I would want to charge enough to produce my own sheets (buy
    plotter).  AutoCAD and a desktop is all you *need*.  I also do not
    know much about the business side of it.  So far I have only charged for me
    doing some work.  I pay taxes on the income, but do not consider it a
    business, yet.  Sorry I could not be of any more help.
    style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
    This
    Tom
    *pkirill
    Re:
    11-21-2002 08:15 AM in reply to: *logardrums
    When I started freelancing, I simply asked the clients what they wanted to
    pay. Or gave them a rate and called it negotiable. Ususally they would
    explain their budget constraints and if I wanted the work, I'd take it to
    help them out and help me out. I also started with smaller firms - while
    they don't throw money around, they tend to be more fair. Typically more
    concerned with having someone dependable that they can afford. Where as the
    larger companies tended to say - here's what we pay, take it or leave it.
    I've found more long term, steady relationships with the smaller firms as
    well.
    "Peter Friedrich" wrote in message
    news:97879613EAC43000A2B03465E822CE38@in.WebX.maYIadrTaRb...
    > Consider---
    schedule,
    > Good Luck!
    > > Hi,
    hr?
    my
    curious
    > bucks
    > > an hour.
    > > Thanks,
    > > Chris
    *Marcus
    11-25-2002 11:45 PM in reply to: *logardrums
    Be very cautious about the contract/agreement you have with a client.
    Liability can raise it's ugly head, make sure that you have it in writing
    that "they" are responsible for the correctness of drawing content.
