CAD Managers
Distinguished Contributor
paul.ashley
Message 1 of 13 (21,623 Views)
32 bit AutoCAD 2008 on 64 bit computer ?
21623 Views, 12 Replies
12-14-2010 07:32 AM
We are moving to AutoCAD 2011 and simultaneously testing machines in the Win 7 64 bit environment.  On one of the 64 bit machines we've installed 2011 and would like to quickly migrate our 2008 settings for preliminary testing.  However, the 2008 32 bit install program says it can't install on a 64 bit machine.  Is there any way around that?
namssurt
Message 2 of 13 (21,610 Views)
Re: 32 bit AutoCAD 2008 on 64 bit computer ?
12-14-2010 09:52 AM in reply to: paul.ashley
Are you installing from disk or from an automated setup? The disk contains both versions, 32 & 64. If your copy does not, contact your reseller to get a disk with both.
jg
paul.ashley
Message 3 of 13 (21,608 Views)
12-14-2010 10:04 AM in reply to: paul.ashley
We were trying an outomated installation for our SMS server and thought perhaps IT does something to the files - like a wrapper - that prevents the installation.  Someone in another department borrowed out disc and didn't return it.  I've located one and hope to try installing with it tomorrow.  The disc says nothing about the bit bersion so I'm hoping that even in 2008 both the 32 and 64 installations were on the same disc.
Valued Contributor
rmiller1973
Message 4 of 13 (21,596 Views)
12-14-2010 01:16 PM in reply to: paul.ashley
If I recall correctly 2008 didn't have an official x64 version. If you contact Autodesk they may send you a link to a 'use at your own risk' x64 version. I know they sent me one but I don't have the link and we have since moved on to where we are currently on 2010.
eviele
Message 5 of 13 (21,358 Views)
01-04-2011 01:34 PM in reply to: rmiller1973
Yeah, there's an "at your own risk" version available from Autodesk. We got it from our reseller I think...
There was no officially supported 64 bit version of ACA 2008 so the "at your own risk" version is the best option.
There are problems though. At least here...
We run it on Win7 64bit and the image hotfix as well as the Service Packs ruin the install. So...we run 2008 without service packs or hotfixes. This impacts stability particularly when inserting images into your cad file.
If you're just using it for migration purposes, you're probably fine.
paul.ashley
Message 6 of 13 (21,353 Views)
01-04-2011 01:47 PM in reply to: paul.ashley
Thanks for the suggestion.  I was off the last two weeks and just this morning thought of asking my reseller if there was something available.  I'll wait to see what I hear and if he hasn't heard about it, I'll mention your post here.
Valued Mentor
jmcintyre
Message 7 of 13 (21,340 Views)
01-04-2011 02:54 PM in reply to: paul.ashley
If vanilla acad is anything like the acad arch install, the MSI has been set to reject installation of 2008 on 64bit OS. The work around is to copy the contents of the DVD onto a machine and edit the MSI file. If you do a search under the autocad architecture forum you will find more detailed instructions. 2009 was the first true 64bit version released if my memory serves me right.
paul.ashley
Message 8 of 13 (21,333 Views)
01-04-2011 05:43 PM in reply to: jmcintyre
I found a website that charted AutoCAD'a compatibility with 64 bit systems and it said that AutoCAD 2008 bit was supported on XP and Vista 64 bit systems but not Windows 7, which is what we're testing on.  Still, your MSI edit idea might work.
Would I edit the MSI using 7-zip as noted in this article?  http://www.ehow.com/how_7290210_edit-msi-file.html
I'll seach the groups to see if I can find the thread you're speaking of.
Thanks.
XlhHarley
Message 9 of 13 (21,036 Views)
01-14-2011 09:35 AM in reply to: paul.ashley
I found this - I haven't tried it yet - but others swear by it...
Here is the advertisement -
http://www.longbowsoftware.com/
paul.ashley
Message 10 of 13 (21,028 Views)
01-14-2011 10:30 AM in reply to: paul.ashley
Is it the case, however, that Autodesk never supported AutoCAD 2008 even on Vista?  Were there problems with it running on post-XP OSs?
You are not logged in.
Manufacturing CAD & IT Manager Resource
Additional information for installing, licensing & deploying Inventor, the Product Design Suites and Factory Design Suites.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
