Buzzsaw Forum Archive
Welcome to Autodesk’s Buzzsaw Forums. Share your knowledge, ask questions, and explore popular Buzzsaw topics.
Word 97 errors - message only
3 REPLIES 3
304 Views, 3 Replies
You are running ProjectPoint inside of Internet Explorer. ProjectPoint is
trying to run Word. Often times Word inside of ProjectPoint which is inside
of Internet Explorer has problems. If you try running ProjectPoint as a
stand-alone application, as in "c:\program files\Buzzsaw.com
ProjectPoint\ProjectPoint.exe" does the problem still occur? My prediction
is that it will not.
"john" <here@there.com> wrote in message
news:C7EC14BEA56C22F030758A54C7F0F996@in.WebX.maYIadrTaRb...
> We are getting Winword errors when trying view or print documents from
> either the local projectpoint application or even going out thru IE 5.0 to
> access our project folders. We are using Word 97 to access word
Documents.
> The error we are getting is:
> This program has performed an illegal operations and will be shut down.
> Once you click the details you get:
> WINWORD caused an invalid page fault in module WINWORD.EXE at
0177:3000fe304
> We are getting this on multiple machine and even while using different
Word
> files on Projectpoint.
3 REPLIES 3
The original of this message with attached file has been moved to
Customer Files
(news://discussion.autodesk.com/autodesk.autocad.customer-files or
http://discussion.autodesk.com/WebX?14@@.ee940b5). Please do not post
files or graphics in product support groups.
See the newsgroup guidelines at
http://discussion.autodesk.com/webx?groundrules.
Anne Brown
Manager, Moderator
Autodesk Product Support discussion groups
Discussion Q&A: http://www.autodesk.com/discussion
Subject:
Word 97 errors
Date:
Fri, 30 Nov 2001 08:56:01 -0800
"john"
Newsgroups:
autodesk.buzzsaw.projectpoint
to
Documents.
0177:3000fe304
Word
I have attached the first error message that we get when this occurs.
Thanks for you help!
Brian
Attachments: winworderror.bmp
We have both environments setup - a couple using
the EXE on the local machine and a couple accessing thru the web, both get the
same error.  I am wondering because we are on a corporate network running
Novell OS and Small business server (that uses Proxy Server) behind a
firewall, could this come into play.  We only allow web and ftp traffic
thru those specified ports.  Does Buzzsaw use specific ports besides port
80 for web traffic?  Is there a list of  Pre Requisite requirements
that we can check, like, the least size PC, the oldest Operating systems, the
oldest version of office, and such that we can check to make sure that we do
meet your requirements?
Thanks again!
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">You
is
inside
ProjectPoint as a
files\Buzzsaw.com
message
from
thru IE 5.0 to
access word
Documents.
is:
get:
WINWORD.EXE at
0177:3000fe304
> We are getting
different
Word
> files on
Projectpoint.
It could be related to the firewall. You should
open up 64.75.26.36 to be sure.
a firewall, could this come into play.  We only allow web and ftp traffic
Thanks again!
is
is inside
ProjectPoint as a
files\Buzzsaw.com
message
from
thru IE 5.0 to
to access word
Documents.
is:
get:
WINWORD.EXE at
0177:3000fe304
> We are getting
different
Word
> files on
Projectpoint.
