there seems to be a problem using the Buzzsaw Windows Client Software (2013.1.25.7638) on a Windows7 64Bit OS (7601.17835.amd64fre.win7sp1_gdr.120503-2030 6.1.1.0.2.48)
Downloading the first folder works.
On download of subsequent folders an error message comes up:
Buzzsaw
Could not send a server request.
Network error: Die Serververbindung konnte nicht hergestellt werden.
Translation: The connection to the server could not be established
Once, this error comes up, no further download is possible.
Closing Buzzsaw and starting the application again does not change this behavior. Every download still leads to this error message.
Logout / Login to the operation system is needed to restart Buzzsaw in a way that download is possible again.
Questions:
Any hint what to do to avoid this error?
Is Buzzsaw 2013 able to run on a Win7 64Bit OS?
Thanks to your answers.
Solved by eric.shipwash. Go to Solution.
Are you using a proxy server on your network?
If you are indeed using a proxy on your network try the steps below
Thanks for this solution.
It works fine and resolves the reproted problem.
