Buzzsaw General
Active Contributor
ForrestJudd
Message 1 of 3 (527 Views)
HTTP 500 error when using View or Edit Online
527 Views, 2 Replies
08-14-2013 10:34 AM
I'm having trouble editing AutoCAD DWG files online when launching from Buzzsaw Web Access.  I've tried multiple browsers, multiple computers, and multiple files.  Each time when I get redirected to AutoCADWS.com I get the following:
HTTP Status 500 -
type Exception report
message
description The server encountered an internal error () that prevented it from fulfilling this request.
exception
javax.servlet.ServletException: java.lang.IllegalArgumentException: Control character in cookie value, consider BASE64 encoding your value
	planplatform.servlet.ApplicationServlet.doPost(ApplicationServlet.java:135)
	planplatform.servlet.ApplicationServlet.doGet(ApplicationServlet.java:61)
	javax.servlet.http.HttpServlet.service(HttpServlet.java:617)
	javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
	planplatform.Auth.AuthFilter.doFilter(AuthFilter.java:148)
	planplatform.cors.CorsFilter.doFilter(CorsFilter.java:61)
root cause
	org.apache.tomcat.util.http.ServerCookie.maybeQuote2(ServerCookie.java:396)
	org.apache.tomcat.util.http.ServerCookie.maybeQuote2(ServerCookie.java:389)
	org.apache.tomcat.util.http.ServerCookie.appendCookieValue(ServerCookie.java:293)
	org.apache.catalina.connector.Response.addCookieInternal(Response.java:1010)
	org.apache.catalina.connector.Response.addCookieInternal(Response.java:979)
	org.apache.catalina.connector.Response.addCookie(Response.java:967)
	org.apache.catalina.connector.ResponseFacade.addCookie(ResponseFacade.java:343)
	planplatform.Auth.CookieManager.setCookie(CookieManager.java:76)
	planplatform.Auth.CookieManager.addCookie(CookieManager.java:26)
	planplatform.Auth.LoginSessionCookiesUtils.addSessionCookies(LoginSessionCookiesUtils.java:27)
	planplatform.login.LoginUtils.createUserTokenAndUpdateCookies(LoginUtils.java:641)
	planplatform.servlet.OpenInWSServlet.internalPost(OpenInWSServlet.java:88)
	planplatform.servlet.ApplicationServlet.doPost(ApplicationServlet.java:122)
Is this a known issue?  It's been happening for several days.  This is also a trial site - I'm not sure if that makes any difference.
I'm able to edit other drawings (already uploaded via other means) using AutoCAD WS and AutoCAD 360 via the browser without issue.
Employee
priwer
Message 2 of 3 (505 Views)
Re: HTTP 500 error when using View or Edit Online
08-19-2013 12:54 PM in reply to: ForrestJudd
Hi ForrestJudd - thanks for the report. We are aware of this issue and are working on a resolution for it. In the meantime, as you've discovered, you can upload files directly to Autodesk 360 and edit them online from there.
Shana
Active Contributor
ArniVidar
Message 3 of 3 (410 Views)
10-31-2013 11:39 AM in reply to: priwer
I am seeing the exact same behavior today.
Is it still not fixed, or broken again?
You are not logged in.
Announcements
Need installation help?
New Buzzsaw Category!
The Buzzsaw forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
